Linker Code Packing Problem
I'm creating an application which runs on Dallas 89C450 microcontroller. My application uses RTX-51 Full RTOS. The versions of the tools which are integrated into my IDE are like below:
C51 Ver: 7.50
A51 Ver: 7.10
My application used to work fine but I was having problems with my available code space. So, I decided to port my application to LX51 Advanced Linker V4.24 in order to use its code packing feature. But my application started malfunctioning after enabling code packing.
What might be going wrong? How can I solve this problem? Using code packing feature is quite important for me because it seems that it would solve my problems with available code space if it worked fine.
Please send me your opinions and advises. This is an emergency case.
Best regards...
  • first i think Andy is a bit soft
    It's sheer folly to expect to get the same output when you switch to a completely different Linker and then change the optimisation levels, too!
    should be
    It's sheer folly to expect to get output that even vaguely resemble the original when you switch to a completely different Linker and then change the optimisation levels, too!</>
    second, after reading the posts one could get the impression that the 'do not' relates to timing loops and such. I would like to state that the most likely reason for what the OP is seeing is that defective code happened to work because of something happened late enough not to cause a problem.
  • "I would like to state that the most likely reason for what the OP is seeing is that defective code happened to work because of something happened late enough not to cause a problem."
    See http://www.keil.com/forum/docs/thread8342.asp
    To re-phrase:
    That is, code that was fundamentally flawed, and only appeared to work by pure luck - your luck ended with the change of Linker and/or optimisation level!
    eg, you had not properly waited for some necessary condition but, luckily, the code happened to be so slow that this didn't matter. Now, with the shiny new improved high-efficiency super-optimising Linker, your code is faster - and so it stops "working".
    It could also go the other way - it's not uncommon that optimising for code size can make it run slower (eg, by converting inline code into subroutine calls). If your code was barely quick enough before, this could make it too slow - and so, again, it would stop working.
  • I couldn't understand why you are acting so that silly.
    "It's sheer folly to expect to get the same output when you switch to a completely different Linker and then change the optimisation levels, too!"
    What the hell is that, ha? I've just asked a question. But you seem to be making yourself happy by insulting people.
    I've changed my linker and optimization level and everything worked fine, genius!!! The problem reveals only when you activate code packing, ok???
  • I know everything you guys had claimed. I know that you can't guarantee exact timing with a high-level language like C but you should use hardware timers instead.
    Do you think that I'm not using timer interrupts within my code, ha? You guys are talking about elemantary things and you think that you're saying something wise.
    Do you think that I'm not aware of that I may carry some of the load onto another processor? I don't have any other processor which I can carry some of the load inside the device that I'm working on, ok???
    Do you think that I'm not aware of that I may observe the operation using a full-blown ICE? I don't have any ICE and I told it right at the beginning. I'm not very grateful with using a printf debugging strategy, either. But that's all I can do because I don't have any other option.
    Do you think that I'm not aware of that I may cancel my all peripheral dependencies and run the application inside the simulator and observe the happenings? I definitely do!!! But I can't use such an option because my processor has to work in cooperation with other processors inside the system which I can't move some of the load. Moreover, it has many peripherals like MIL-STD-1553 chip which you can't simulate inside Keil environment. The operation strictly depends on this peripheral and cancellation of such a peripheral would not give me any idea about the operation of my code on the real hardware!!!
    I know as good as you guys that you can't expect the same code result by changing the linker and optimization levels, etc. But the vendor of the application development environment has to guarantee that the main operation of my system will not be affected by changing the tools or optimization levels, etc. Otherwise, what does it stand for???
    I was just trying to investigate wheter anybody had faced with such a problem after enabling code packing option provided by advanced linker. And if yes, how they solved it. That's all. But you guys seem to have fun.
    Carry on!!!
  • while I usually refrain from responding to "hate mail" there is one issue in the above that I will respond to
    first you state:
    Later you say: the vendor of the application development environment has to guarantee that the main operation of my system will not be affected by changing the tools or optimization levels, etc. Otherwise, what does it stand for???
    How do you make those two statements go together. I do understand that we have upset your fragile sensibilities by suggesting that the fault is is your code (how awful, your code is, of course, perfect) but every experienced developer has seen examples of "faulty code that happen to work" which, I am 98% sure is the case here.
    So, go ahead, sit in the corner, cry and blame the tools or pull up your pants and fix your code.
