How to jump to assigned place after interrupt occurs ?
I want to implement following job in C code with Keil C51.
(1) jump to a place (function entry) after an interrupt occurs.
I know how to implement it in assemble, but I don't know how to implement it in C ?
Following is the implementation in assemble,
JUMP_HERE: CLR A
Int1: MOV DPTR,#JUMP_HERE
PUSH DPL
PUSH DPH
RETI
Does following C code works ?
void main()
while(1)
JUMP_HERE:
func1();
void
Int0_ISR (void) interrupt 0 using 1
// C code here
#pragma asm
MOV DPTR,#JUMP_HERE
PUSH DPL
PUSH DPH
#pragma endasm
I know you can only use the goto statement within same function in C.
Any idea ? Thanks.
Daniel
