How to read data from a text file
Hi all,
i need to read data from a text file and write in keil µvision program.
How to open file, read, write and close file works in µvision programs.
Thanking you,
  • "but we r developing a project in that we make a transmitt mode"
    What will be transmitted? From where? By what?
    What is your "transmitter" code - on what target platform will it run?
  • uVision can read and write files with OPEN/SAVE from the file menu.
    In AGSI-DLLs you can do everything too.
    But this works only inside the simulator.
    Good luck.
  • "uVision can read and write files with OPEN/SAVE from the file menu."
    Yes - but, as already noted, that just opens the file in an editor window.
  • Do you want to compile this file?
    If so have your GUI create a C file (or header) with the correct data, then save it to the uP folder.
    "What we have here is a failure to Comunicate"
  • "have your GUI create a C file (or header) with the correct data"
    Yes - I have already suggested that twice!
    Absolutely!
    There appear to be 3 issues here:
    1. The OP, by his own admission, is not an embedded developer, and knows nothing about embedded development;
    2. The OP, by his own admission, knows nothing about uVision - what it is, what it does nor how to use it;
    3. We are trying to discuss all this in a foreign language!
    None of this is a criticism of the OP - it just makes communication almost impossible!
    This is why I've suggested a couple of times that he gets his embedded developer(s) to describe what's going on - then they might be able to describe the real requirement, and we might be able to come up with a spec for the GUI that a VC developer could understand.
    As it stands, I'm still not convinced that the OP understands the difference between uVision & what it does on the PC, and the actual embedded application running on the target hardware - I'm not sure that he really wants compile-time configuration, rather than a run-time user interface...
    Maybe your fresh set of ears can understand him better than mine?
  • Hi ,
    sorry that i opened another thread,
    i wanted to say that i need to use Read, and write .txt,.xml files in C51 programs.
    Thanking you.
  • "i need to use Read, and write .txt,.xml files in C51 programs."
    Are we still talking about files created by your PC-based GUI?
    Remember: C51 programs run on 8051 processors in embedded hardware - they do not run on PCs!
    Therefore, before doing any file operations in a C51 program, you will have to implement a file system on the embedded target hardware!
    Part of implementing the file system will be to provide the necessary functions to read & write files.
    Once you have implemented your file system on your embedded target hardware, you will also have to figure out a way to get the files generated on your PC by your GUI from the PC and onto your embedded target hardware.
    I don't think you really want to do that, do you??!
    You still haven't said why you can't have your GUI generate a 'C' source file...
