Compiler warning - why?
I am just learning C by starting on modifying an example program to do what I want it to do. But immediately get warning messages although the compiled program runs fine. Whenever I declare a variable I get the following warnings.
Measure.c(153): warning: #550-D: variable "Minn_flag" was set but never used
Measure.c(62): warning: #550-D: variable "Ret_flags" was set but never used
Ret_Flags is declare as a global at the head of a file, and used in two functions. Minn_flag is declared inside a function and used once. I dont understand because I am declaring and using variables right alongside others already used in the example. Those variables dont get errors, but mine do. I am sure it's basic but what am I doing wrong?
Thanks!
  • "I have just toured uvision3 and I couldn't find where you can select an alternative editor"
    I don't think you can - you're stuck with the "integrated" one.
    However, there's nothing to stop you using an external editor, and just using uVision for building, debugging, etc.
    You can set up entries on the Tools menu to launch your own editor, and you can use the Key Sequences to have in start at the current location in the current file, etc;
    http://www.keil.com/support/man/docs/uv3/uv3_dg_toolmnu.htm
    There is a certain other 8051 tool vendor whose "IDE" is, in fact, CodeWirght. By downloading their demo version, you can effectively get a free Codewright!
    I couldn't possibly name names here, of course... ;-)
    "As to the nested comments, uvision seems to work fine in all respects."
    Now this is where you can come unstuck with stuff like nested comments. uVision is not your compiler - so it is perfectly possible that uVision could be happy to colour your nested comments as you like it, while the actual compiler would throw them out.
    The same applies to any other editor, of course.
    "I dont really like the /* .. */ commenting I find the // ... gives a cleaner look to the code"
    I entirely agree on that one.
    Shame that // isn't strictly "ANSI" C, though... :-(
  • BTW: Did your post just suffer from the mystery missing line breaks?
    http://www.keil.com/forum/docs/thread8601.asp
  • Thanks for the info. But I will stay with the integrated editor for now, unless there are big reasons not to. It's bad enough trying to learn C, the environment, the quirks and the ARM chip itself. I spent a few hours the other day trying to get the RTOS working only to find out that the standard Startup.S wont work as is. I am more experienced in Forth and the 8051 family.
    So far the /* ... */ editing is working fine the compiler has not wobbled or done anything unexpected.
    Have a good weekend.
  • Dont know what happened to the linebreaks the preview looked OK before I posted it.
