Site
Search
User
Site
Search
User
Support forums
Keil forum
Problem with GCC and string.h and stdlib
Jump...
Cancel
State
Not Answered
Locked
Locked
Replies
Subscribers
22 subscribers
Views
Users
0 members are here
Arm Compiler
Keil
GCC
uVision
GNU
Options
More actions
Cancel
Related
nehal nehal
over 12 years ago
Note: This was originally posted on 8th October 2008 at
http://forums.arm.com
Hi everyone,
i have following trouble with keil arm gnu compiler. i have recently moved to gnu and now i am having hard time to set it up.
description of problem: i am using real view arm compiler uvison3.5. i am using gnu chain tool set for aduc7021 (analog device) arm. when i tried to compile my code it gives me following errors:
"error: undefined reference to 'memcpy'
error: undefined reference to '_divsi3'
error: undefined reference to 'strcat'
error: undefined reference to 'memset'""
i tried to include string.h and stdlib.h in my project but it didn't help.
so if anybody can explain what is going on then it would be a great help.
thanks
nehal
0
Jacob Bramley
over 12 years ago
Note: This was originally posted on 9th October 2008 at
It appears that you haven't linked the standard libraries correctly.
It's important to realize the difference between the compiler and the linker.
The
compiler
takes your source files and translates them into object files. Typically, these objects will include the assembly source and a number of symbols which the linker will use. The compiler doesn't know or care where resources (such as
memcpy
or
__divsi3
) exist, provided that they're declared in a header somewhere. Your C headers just tell the compiler "you can use this function, and here's its prototype".
The
linker
takes your object files and glues them all together. This generally entails resolving symbols to addresses and fitting your code into a memory structure. However, the headers you specified to the compiler mean nothing here; they just tell the compiler which symbols to add to the object file so the linker knows what to look for. The linker will search through all objects and any linked libraries for the symbols, and it will complain if it can't find them. That seems to be what's happening in your case.
IDEs such as uVision often hide this relationship from the user, but it is important to understand.
Having said that, the functions you listed are part of the standard C library, and as such they should be linked by default. You generally have to explicitly tell the linker to exclude the standard libraries, though it is common to exclude them for embedded targets and so your IDE may be configured to do that by default.
I'm not familiar with uVision so I can't really help you with finding the correct options...
Cancel
Vote up
0
Vote down
Cancel
0
Jacob Bramley
over 12 years ago
The
compiler
memcpy
or
__divsi3
The
linker
Cancel
Vote up
0
Vote down
Cancel
