Accessing External Memory Devices
Hey all,
I am using uVision 3 and a Phytec 2294 board.
I have an external memory device connected to the phytec expansion board. The external device is using /CS0, although from talking to phytec, I am not sure if that is quite right.
I have set up the external memory space in the project options like so:
Start: 0x80000000 Size: 0x4
When I define a variable like :
#define volatile var x __at 0x8000000
and step through my code, any write/read to that variable doesnt seem to take place at the right addresses.
Can anyone give a clue as to what I may have missed?
Doug
  • Dan,
    I have taken a more simplistic approach for the time being.
    I have created a new projeect, with my definition of:
    #define MY_REG1 (*(volatile unsigned char *)0x83000000)
    In the dissasembler, when writing to the register I see
    0x00000608  B500      PUSH      {LR}
        30:   MY_REG1 = 1;
        31:
    My code base is currently set to 0x00000000
    Its got me stumped currently.
  • To answer original question, this is just in simulator
  • Nothing after that?
    Can you show more disassembly context?
  • 0x00000606 E7F1 B 0x000005EC
    27: int main (void) {
    28: unsigned int j; /* LED var */
    29:
    30: MY_REG1 = 1;
    31:
    0x0000060A 2101 MOV R1,#0x01
    0x0000060C 4813 LDR R0,[PC,#0x004C]
    0x0000060E 7001 STRB R1,[R0,#0x00]
    32: IODIR1 = 0xFF0000; /* P1.16..23 defined as Outputs */
    33:
    0x00000610 4913 LDR R1,[PC,#0x004C]
    0x00000612 4814 LDR R0,[PC,#0x0050]
    0x00000614 6001 STR R1,[R0,#0x00]
    34: init_timer();
  • Much better. Thank you.
    29:
    0x00000608 B500 PUSH {LR}           ;Just saving some processor context there.
    30: MY_REG1 = 1;
    31:
    0x0000060A 2101 MOV R1,#0x01        ;Loading R1 with the value to be written.
    0x0000060C 4813 LDR R0,[PC,#0x004C] ;Loading R0 with the address to write to.
    0x0000060E 7001 STRB R1,[R0,#0x00]  ;Performing the byte write.
    What's probably throwing you here is at 0x0000060C with the load of R0 with 0x83000000 not being obvious. What is being loaded into R0 is the value the compiler stored at (PC + 0x4C). If you were to look further down in memory at 0x0000065C (or thereabouts), you should see 0x83000000 stored there. That's where the compiler stored our target address.
  • Dan,
    Another thing I just noticed is that if I stored this in the target options
    start of 0x83000000, and size of 0x4,
    the compiler gives me this:
    *** ERROR L107: ADDRESS SPACE OVERFLOW
        SPACE:   DATA
        SEGMENT: STACK
        LENGTH:  00000490H
    *** WARNING L23: UNRESOLVED EXTERNAL SYMBOLS
    *** ERROR L128: REFERENCE MADE TO UNRESOLVED EXTERNAL
        SYMBOL:  ?C?INIT
        ADDRESS: 00000104H
    Program Size: data=1172 const=0 code=296
    Target not created
    But if I give it a much larger size, like 0x4000, it takes it just fine and operates properly, Any idea why it doesnt like the smaller size?
    Doug
  • "Any idea why it doesnt like the smaller size?"
    The only thing I can think of is that the mapper is designed to deal with larger chunks, for example >=256-bytes.
    My Linux kernel rounds everything up to 4KiB pages ;-)
  • Dan,
    Thanks again for your help today.
    I think this is enought to go on for now.
    If I need to specify a bigger chunk, its not too much of a big deal :) Im going to use it or im not, end of that.
    Again, thanks for the assistance.
    This beginning embedded guy really appreciates it :)
