Support for calling through function pointer tables
does anyone know if Keil has added support for calls through a function pointer table, or if they are about to do so?
Right now it is a bomb, especially when using banked memory.
/Christian
  • No,
    I has nothing to do with hardware what so ever. And yes the 8051 wasn't designed with complex calling in mind, but that is not saying that you can't!
    What I am talking about is purely compiler related. Please make no mistake about that.
    Forget about target type - it has no meaning here. We have compiler 'A' from company 'A-soft'. Can you make a compiler that can handle function trees through function pointers? The answer is without question yes! Are there limitations depeding on target? The answer is again yes.
    Does this mean that function pointer utilization and data overlaying is not possible? The answer is no!
    True, the 8051 has a very noticable limit, but the compiler can easily use X-stack for parameters and thereby overcome much of the limitations.
    Don't narrow your sigth by looking at hardware restrictions. Look forward and investigate how you can overcome obstacles. If everybody said 'that is impossible' then we would get no where. There isn't anything you can't do with the 8051, as long as you don't exceed the memory limits.
    The Keil compiler is VERY EFFICIENT when it comes to generate efficient code for the 8051 (I have never questioned this), so I think that it is a shame that it can't go all the way.
    It is tad annoying that you have to take different compiler capabilities into consideration when writing code, when they all should be able to handle the same code.
    /Christian
  • The Keil compiler is VERY EFFICIENT when it comes to generate efficient code for the 8051 (I have never questioned this), so I think that it is a shame that it can't go all the way.
    EXACTLY and the price for the efficieny is that function calls becomes "troublesome". When there is a tradeoff some will always disagree with the decision. All I am saying is that if you do not like the tradeoff Keihas made, get another compiler.
    That statement is, in my opinionn, pure and unadulterated bullshit. That would mean that Keil '51 should not have a bit variable because Visual C does not.
  • Sigh!
    I thought that it was pretty obvious that we were taking about standard C code and not specific compiler instructions as 'Setbit', which refers directly to assembler instructions.
    What you are saying is almost like: "the compiler doesn't need to handle switch-case statements as it handles if-else more effieciently". And that doesn't make sense.
    I am not talking about making trade-offs with the existing Keil optimizations but to add some extra functionality that will improve handling of function pointers in a Keil environment.
    Forget about it. I don't think you understand what I am talking about.
  • Forget about it. I don't think you understand what I am talking about.
    Oh yes, I do.
  • Can you make a compiler that can handle function trees through function pointers? The answer is without question yes!
    Perhaps yes when the pointer table has constant values, but if the function pointers are 'dynamic', I think probably not practically.
  • Yes, that is right. Dynamic function pointers are impossible to work with (optimization wise). But for static pointers it should be.
    Thanks to you Hans-Bernhard for a very detailed reply. You know what you are talking about
    /Christian
  • "Forget about it. I don't think you understand what I am talking about."
    "Oh yes, I do."
    No, you only think you do, but you're so wrapped up in one of your favourite rants that you haven't noticed yet that you don't. I suggest you take the time to read the thread carefully.
