sEOS running a dummy tast
Please, any one can help me to explain the following function:
Q1) Function X_Init
Q2) Function X
Q3) Function sEOS_ISR()
Q4) Function sEOS_Go_To_Sleep
Code:
#include <reg52.h>
#define OSC_FREQ (12000000UL)
#define OSC_PER_INST (12)
void sEOS_Init_Timer2(const unsigned char);
void sEOS_Go_To_Sleep(void);
void X_Init(void);
void X(void);
void X_Init(void);
#define INTERRUPT_TIMER_2_Overflow 5
void main(void)
X_Init(); // prepare for dummy task
sEOS_Init_Timer2(60); // set up simple EOS (60ms tick interval)
while(1)
sEOS_Go_To_Sleep();
void X_Init(void)
// Dummy task init function
// Dummy task init...
void X(void)
// Dummy task called from sEOS ISR
// Dummy task....
void sEOS_ISR() interrupt INTERRUPT_TIMER_2_Overflow
TR2 = 0;
X();
void sEOS_Init_Timer2(const unsigned char TICK_MS)
unsigned long Inc;
unsigned int Reload_16;
unsigned char Reload_08H, Reload_08L;
T2CON = 0x04;
Inc = (TICK_MS * (OSC_FREQ/1000)) / OSC_PER_INST;
// Inc = 60,000 = 0xEA60
Reload_16 = (65536UL - Inc); // Reload_16 = 5536 =0x15A0
Reload_08H = (Reload_16 / 256);
Reload_08L = (Reload_16 % 256);
TH2 = Reload_08H; // 0x15
RCAP2H = Reload_08H;
TL2 = Reload_08L; // 0xA0
RCAP2L = Reload_08L;
ET2 = 1;
TR2 = 1;
EA = 1;
PCON |= 0x01; // enter idle mode (generic 8051 version)
Thank You
  • Please, any one can help me to explain the following function
    If you can't explain it, why did you code it that way.
    If the reason you need it explained is that it is "inherited" code, do like most of us: if you do not understand it, recode it.
  • Hi,
    The code is like that if i cancel the function X and X_Init, so what are the different between the bellow code and the original code??
    #include <reg52.h>
    void X_Init(void);
    void X(void);
    void X_Init(void);
    void main(void)
    while(1)
    sEOS_Go_To_Sleep();
    TR2 = 0;
    unsigned long Inc;
    T2CON = 0x04;
    ET2 = 1;
    TR2 = 1;
    EA = 1;
