How covert " C" to assembly
Dear sir;
I had written program with Keil and i dont like to give it to other but i want to give assembly to him that he can compile this assembly code to HEX.
please guide me how can i converted it to assembly for compilng it to hex.
As you mentioned Keil have a project.lst includes C program and assembly but i couldnt
use it for compile to hex.(Do you understand me or not?)
j.majd@engineer.com
  • "the OP has repeatedly stated that he has to supply source."
    Has he?
    You must be interpreting his repeated posts of "becuase i have to give him" as deliberate, then?
    They just look like finger-trouble to me - which is not uncommon on this forum.
  • You must be interpreting
    Oh, Stefan is, he just has a problem with you not interpreting it the same way.
    I would love to get back to discussing technical matters, but Stefan keep bringing in Personal idiosyncracies instead of just providing an alternate solution. If Stefan thinks it is more important to critisize my style (rather than the content) then I fail to see what good his posts do.
    Stefan, if you can prove that suggesting a library would get the OP in trouble I will retract, but since you can't I suggest you do.
    Trevlig helg
  • "I would love to get back to discussing technical matters, but Stefan keep bringing in Personal idiosyncracies instead of just providing an alternate solution. If Stefan thinks it is more important to critisize my style (rather than the content) then I fail to see what good his posts do."
    I'm criticising the fact that you keep expressing unfounded opinion as though it were The Absolute Truth. While your style is somewhat irritating the important point is the content which is at best misleading and at worst wrong. My posts attempt to provide an indication to others that your comments should not be taken as statements of fact and hopefully to encourage you to see that there is a world out here where all things do not conform to the gospel according to Erik.
    "Stefan, if you can prove that suggesting a library would get the OP in trouble I will retract, but since you can't I suggest you do."
    When did I say that suggesting a library would get the OP in trouble? What exactly would you like me to 'retract'?
  • "Given that he's had all this for free, don't you think it would at least be courteous of him to say why a library is not appropriate to his situation?"
    At the expense of sounding like a stuck record myself, he has explained this. He said he has to supply source, therefore a library would be inappropriate.
  • ""the OP has repeatedly stated that he has to supply source."
    Has he?
    They just look like finger-trouble to me - which is not uncommon on this forum."
    No problem, please reread as:
    'the OP has stated that he has to supply source.'
  • "'the OP has stated that he has to supply source."
    No, he hasn't.
    Here's what he said:
    "I had written program with Keil and i dont like to give it to other but i want to give assembly to him that he can compile this assembly code to HEX."
    He said he wants to give assembly - he does not say that there is any specific requirement to give assembly; that's just the way he wants to do it.
    I told him how to do that, but I have also advised that using a Library would be a better approach.
    If he'd care to comment on why a Library is not appropriate to his particular requirement, perhaps we might all learn something...
