Hi, i got this this error while trying to add some assembly code to my C. How do i activate the src-control? Any help is appreciated. Thank you! error C272: 'asm/endasm' requires src-control to be active
4) next step? 4) assemble and link in the /a51 module Erik
You may want to look at the following thread: http://www.keil.com/forum/docs/thread5517.asp Jon
Explained here. http://www.keil.com/forum/docs/thread1394.asp
"1) Firstly, i create a 'skeleton' C code for my desired asm. but what do u exactly mean by that? what should i type in the 'skeleton' C code?" A "skeleton" 'C' delay function would look some thing like this:
void delay( unsigned char duration ) { // Nothing in the body - it's just a skeleton! }
So, this will be my 'skeleton' C code??
#include <reg52.h> /* Function declarations */ void delay( unsigned char duration ); /* Program routines */ void main (void) { } void delay( unsigned char duration ) { // Nothing in the body - it's just a skeleton! }
; .\TestMode.SRC generated from: TestMode.C ; COMPILER INVOKED BY: ; C:\Keil\C51\BIN\C51.EXE TestMode.C BROWSE DEBUG OBJECTEXTEND SRC(.\TestMode.SRC) $NOMOD51 NAME TESTMODE P0 DATA 080H P1 DATA 090H P2 DATA 0A0H P3 DATA 0B0H T0 BIT 0B0H.4 AC BIT 0D0H.6 T1 BIT 0B0H.5 T2 BIT 090H.0 EA BIT 0A8H.7 IE DATA 0A8H EXF2 BIT 0C8H.6 RD BIT 0B0H.7 ES BIT 0A8H.4 IP DATA 0B8H RI BIT 098H.0 INT0 BIT 0B0H.2 CY BIT 0D0H.7 TI BIT 098H.1 INT1 BIT 0B0H.3 RCAP2H DATA 0CBH PS BIT 0B8H.4 SP DATA 081H T2EX BIT 090H.1 OV BIT 0D0H.2 RCAP2L DATA 0CAH C_T2 BIT 0C8H.1 WR BIT 0B0H.6 RCLK BIT 0C8H.5 TCLK BIT 0C8H.4 SBUF DATA 099H PCON DATA 087H SCON DATA 098H TMOD DATA 089H TCON DATA 088H IE0 BIT 088H.1 IE1 BIT 088H.3 B DATA 0F0H CP_RL2 BIT 0C8H.0 ACC DATA 0E0H ET0 BIT 0A8H.1 ET1 BIT 0A8H.3 TF0 BIT 088H.5 ET2 BIT 0A8H.5 TF1 BIT 088H.7 TF2 BIT 0C8H.7 RB8 BIT 098H.2 TH0 DATA 08CH EX0 BIT 0A8H.0 IT0 BIT 088H.0 TH1 DATA 08DH TB8 BIT 098H.3 EX1 BIT 0A8H.2 IT1 BIT 088H.2 TH2 DATA 0CDH P BIT 0D0H.0 SM0 BIT 098H.7 TL0 DATA 08AH SM1 BIT 098H.6 TL1 DATA 08BH SM2 BIT 098H.5 TL2 DATA 0CCH PT0 BIT 0B8H.1 PT1 BIT 0B8H.3 RS0 BIT 0D0H.3 PT2 BIT 0B8H.5 TR0 BIT 088H.4 RS1 BIT 0D0H.4 TR1 BIT 088H.6 TR2 BIT 0C8H.2 PX0 BIT 0B8H.0 PX1 BIT 0B8H.2 DPH DATA 083H DPL DATA 082H EXEN2 BIT 0C8H.3 REN BIT 098H.4 T2CON DATA 0C8H RXD BIT 0B0H.0 TXD BIT 0B0H.1 F0 BIT 0D0H.5 PSW DATA 0D0H ?PR?main?TESTMODE SEGMENT CODE ?PR?_delay?TESTMODE SEGMENT CODE ?DT?_delay?TESTMODE SEGMENT DATA OVERLAYABLE EXTRN CODE (?C_STARTUP) PUBLIC _delay PUBLIC main RSEG ?DT?_delay?TESTMODE ?_delay?BYTE: duration?140: DS 1 ; #include <reg52.h> ; ; ; /* Function declarations */ ; void delay( unsigned char duration ); ; ; /* Program routines */ ; void main (void) RSEG ?PR?main?TESTMODE main: ; SOURCE LINE # 8 ; { ; SOURCE LINE # 9 ; ; } ; SOURCE LINE # 11 RET ; END OF main ; ; void delay( unsigned char duration ) RSEG ?PR?_delay?TESTMODE _delay: ; SOURCE LINE # 13 MOV duration?140,R7 ; { ; SOURCE LINE # 14 ;I'm suppose to insert my asm code here?? ; // Nothing in the body - it's just a skeleton! ; } ; SOURCE LINE # 16 RET ; END OF _delay END
PWM EQU P0.1 ORG 0000H MAIN MOV R3,#50 ; this is the value that i want to change (the duration value in the skeleton C code) LOOP: SETB PWM CALL DELAY CLR PWM CALL DELAY DJNZ R3,LOOP CLR MRUN JMP $ DELAY: MOV R4,#3 DEL: MOV R2,#00FFH DJNZ R2,$ DJNZ R4,DEL RET END
Sorry for cut & paste my entire code here, i just want to make sure that i got everything right. Thanks
" i just want to make sure that i got everything right." No: you need to put the delay routine in a separate 'C' file - all on its own. It is only the delay function that you want in assembler - you are currently converting main() as well!
Thanks! This is the 'updated' .A51 code from .src I included my ASM code in it, and this time i didn't include the main. Is this correct?
; .\TestMode.SRC generated from: TestMode.C ; COMPILER INVOKED BY: ; C:\Keil\C51\BIN\C51.EXE TestMode.C BROWSE DEBUG OBJECTEXTEND SRC(.\TestMode.SRC) $NOMOD51 NAME TESTMODE P0 DATA 080H P1 DATA 090H P2 DATA 0A0H P3 DATA 0B0H T0 BIT 0B0H.4 AC BIT 0D0H.6 T1 BIT 0B0H.5 T2 BIT 090H.0 EA BIT 0A8H.7 IE DATA 0A8H EXF2 BIT 0C8H.6 RD BIT 0B0H.7 ES BIT 0A8H.4 IP DATA 0B8H RI BIT 098H.0 INT0 BIT 0B0H.2 CY BIT 0D0H.7 TI BIT 098H.1 INT1 BIT 0B0H.3 RCAP2H DATA 0CBH PS BIT 0B8H.4 SP DATA 081H T2EX BIT 090H.1 OV BIT 0D0H.2 RCAP2L DATA 0CAH C_T2 BIT 0C8H.1 WR BIT 0B0H.6 RCLK BIT 0C8H.5 TCLK BIT 0C8H.4 SBUF DATA 099H PCON DATA 087H SCON DATA 098H TMOD DATA 089H TCON DATA 088H IE0 BIT 088H.1 IE1 BIT 088H.3 B DATA 0F0H CP_RL2 BIT 0C8H.0 ACC DATA 0E0H ET0 BIT 0A8H.1 ET1 BIT 0A8H.3 TF0 BIT 088H.5 ET2 BIT 0A8H.5 TF1 BIT 088H.7 TF2 BIT 0C8H.7 RB8 BIT 098H.2 TH0 DATA 08CH EX0 BIT 0A8H.0 IT0 BIT 088H.0 TH1 DATA 08DH TB8 BIT 098H.3 EX1 BIT 0A8H.2 IT1 BIT 088H.2 TH2 DATA 0CDH P BIT 0D0H.0 SM0 BIT 098H.7 TL0 DATA 08AH SM1 BIT 098H.6 TL1 DATA 08BH SM2 BIT 098H.5 TL2 DATA 0CCH PT0 BIT 0B8H.1 PT1 BIT 0B8H.3 RS0 BIT 0D0H.3 PT2 BIT 0B8H.5 TR0 BIT 088H.4 RS1 BIT 0D0H.4 TR1 BIT 088H.6 TR2 BIT 0C8H.2 PX0 BIT 0B8H.0 PX1 BIT 0B8H.2 DPH DATA 083H DPL DATA 082H EXEN2 BIT 0C8H.3 REN BIT 098H.4 T2CON DATA 0C8H RXD BIT 0B0H.0 TXD BIT 0B0H.1 F0 BIT 0D0H.5 PSW DATA 0D0H ?PR?_delay?TESTMODE SEGMENT CODE ?DT?_delay?TESTMODE SEGMENT DATA OVERLAYABLE PUBLIC _delay RSEG ?DT?_delay?TESTMODE ?_delay?BYTE: duration?040: DS 1 ; #include <reg52.h> ; ; void delay( unsigned char duration ) RSEG ?PR?_delay?TESTMODE _delay: MOV duration?040,R7 ;my assembly starts here PWM EQU P0.1 MRUN EQU P0.4 MDIR EQU P0.3 MRST EQU P0.2 MUP EQU P0.0 ORG 0000H MAIN: MOV P0, #0FFH SETB MRST SETB MUP SETB MDIR ;MOV R3,#50 this is the value that i want to change (the duration value in the skeleton C code) LOOP: SETB PWM CALL DELAY CLR PWM CALL DELAY ;DJNZ R3,LOOP since it brought in to R7 so i replace it here? DJNZ R7,LOOP CLR MRUN JMP $ DELAY: MOV R4,#3 DEL: MOV R2,#00FFH DJNZ R2,$ DJNZ R4,DEL RET ; END OF _delay END
"this time i didn't include the main." I think you must've posted the wrong code - it looks exactly the same as before. Remember, the only thing you need to do in assembler is the delay function; there should be no ORG, no fiddling with Ports, no CALL to the delay function - just the delay loop itself. Remember, the only reason you're doing this in assembler is so that you can know for sure exactly what machine instructions will be executed and, thus, exactly how long each iteration of the loop will take. You don't need to worry about this for the rest of your program, so you can just write that in straight 'C'
sorry.. So is this correct?
; .\TestMode.SRC generated from: TestMode.C ; COMPILER INVOKED BY: ; C:\Keil\C51\BIN\C51.EXE TestMode.C BROWSE DEBUG OBJECTEXTEND SRC(.\TestMode.SRC) $NOMOD51 NAME TESTMODE P0 DATA 080H P1 DATA 090H P2 DATA 0A0H P3 DATA 0B0H T0 BIT 0B0H.4 AC BIT 0D0H.6 T1 BIT 0B0H.5 T2 BIT 090H.0 EA BIT 0A8H.7 IE DATA 0A8H EXF2 BIT 0C8H.6 RD BIT 0B0H.7 ES BIT 0A8H.4 IP DATA 0B8H RI BIT 098H.0 INT0 BIT 0B0H.2 CY BIT 0D0H.7 TI BIT 098H.1 INT1 BIT 0B0H.3 RCAP2H DATA 0CBH PS BIT 0B8H.4 SP DATA 081H T2EX BIT 090H.1 OV BIT 0D0H.2 RCAP2L DATA 0CAH C_T2 BIT 0C8H.1 WR BIT 0B0H.6 RCLK BIT 0C8H.5 TCLK BIT 0C8H.4 SBUF DATA 099H PCON DATA 087H SCON DATA 098H TMOD DATA 089H TCON DATA 088H IE0 BIT 088H.1 IE1 BIT 088H.3 B DATA 0F0H CP_RL2 BIT 0C8H.0 ACC DATA 0E0H ET0 BIT 0A8H.1 ET1 BIT 0A8H.3 TF0 BIT 088H.5 ET2 BIT 0A8H.5 TF1 BIT 088H.7 TF2 BIT 0C8H.7 RB8 BIT 098H.2 TH0 DATA 08CH EX0 BIT 0A8H.0 IT0 BIT 088H.0 TH1 DATA 08DH TB8 BIT 098H.3 EX1 BIT 0A8H.2 IT1 BIT 088H.2 TH2 DATA 0CDH P BIT 0D0H.0 SM0 BIT 098H.7 TL0 DATA 08AH SM1 BIT 098H.6 TL1 DATA 08BH SM2 BIT 098H.5 TL2 DATA 0CCH PT0 BIT 0B8H.1 PT1 BIT 0B8H.3 RS0 BIT 0D0H.3 PT2 BIT 0B8H.5 TR0 BIT 088H.4 RS1 BIT 0D0H.4 TR1 BIT 088H.6 TR2 BIT 0C8H.2 PX0 BIT 0B8H.0 PX1 BIT 0B8H.2 DPH DATA 083H DPL DATA 082H EXEN2 BIT 0C8H.3 REN BIT 098H.4 T2CON DATA 0C8H RXD BIT 0B0H.0 TXD BIT 0B0H.1 F0 BIT 0D0H.5 PSW DATA 0D0H ?PR?_delay?TESTMODE SEGMENT CODE ?DT?_delay?TESTMODE SEGMENT DATA OVERLAYABLE PUBLIC _delay RSEG ?DT?_delay?TESTMODE ?_delay?BYTE: duration?040: DS 1 ; #include <reg52.h> ; ; void delay( unsigned char duration ) RSEG ?PR?_delay?TESTMODE _delay: MOV duration?040,R7 DELAY: MOV R4,#3 ;start of my delay code DEL: MOV R2,#00FFH DJNZ R2,$ DJNZ R4,DEL DJNZ R7, DELAY ; is this how u bring in the duration value that was passed in R7? RET ; END OF _delay END
