Hi, i need to use read and write .xml fimes in my µvision program. how can i do this? Thanking you.
Don't keep starting new threads on the same subject! http://www.keil.com/forum/docs/thread7057.asp http://www.keil.com/forum/docs/thread7044.asp You can't start processing XML before you've got the basics of reading a text file! It is still unclear what exactly you want to read from this file, and what you want uVision to do with the data that it reads!
You have now had 2 independant suggestions to generate 'C' source files. This is the approach taken by Code Architect. Why don't you give Code Architect a try; eg, http://www.codearchitect.org/philips/v2/index.php?co_tree=89LPC901%23Watchdog Having seen what it does, if the approach is not suitable then please explain why not. Note: I am not suggesting that Code Architect is the solution to your requirement; I am suggesting that the approach used by Code Architect (ie, generate 'C' source) may be suitable...
