Is it possible to open two projects simultaneously? I have master/slave project with PK-ARM and PK51. Master is ARM (LPC2138), slave is LPC900 (P89LPC9107). Communication is single wire, modified UART. Now I would like to test it with MCB900 and MCB2130. How can I use both projects at the same time on same PC?
Just start two instances of uVision and load the two projects. Reinhard
