Checksum calculation of a specific part of the code
Is it possible to force the compiler (with a directive or something) to store a specific part of the code in a predefined area in the memory?
What I want to do is to be able to calculate a checksum of some specific functions in my code, so I later can prove that they are unchanged since the last build.
My thought is that if I know in which memory area these functions are located then I can simply calculate a checksum of this area.
Any ideas, someone?
  • If you locate the code and the variables it references at fixed addresses, you have a chance of getting same binary image every time you link your program. This is not guaranteed though. The linker has the right to do optimizations like replacing absolute jumps with relative ones, reorder sections as it sees fit and so on. You have to keep an eye on those. But with some luck you could get away with it.
    Of course, the fixed code should be in a compiled form (.OBJ or .LIB), because the compiler output is even more sensitive to command line switches, compiler version and who knows what else.
    These variables must be permanently located at absolute addresses in an assembler module.
    You don't have to use assembler to locate your variables at fixed addresses. There are linker controls which allow you to do that:
    http://www.keil.com/support/docs/586.htm
    Same goes for locating code. If the code is contained in several .C files, you can combine them into a class using the RENAMECLASS compiler directive:
    http://www.keil.com/support/man/docs/c166/c166_renameclass.htm
    I have problems with finding out the address area for the external flash EEPROM.
    Hopefully you have the schematic diagram for your board. If not, you will have to figure out how the external EEPROM is wired to the MCU (address, data and chip select lines). This should give you enough information to figure out what addresses you can allocate for the EEPROM.
    Regards,
    - mike
  • The linker has the right to do optimizations like replacing absolute jumps with relative ones, reorder sections as it sees fit and so on. You have to keep an eye on those. But with some luck you could get away with it.
    someone please confirm/define: with optimization set no higher than x, the linker will not replace opcodes.
    Read my post, I said the same just that using assembler is a whole lot easier (you do not have to define the location of each and every)
  • "(you do not have to define the location of each and every)"
    Each and every what?
  • Each and every what?
    Variable
    sorry, got a phone call
  • "Each and every what?
    Variable"
    You don't need to with 'C' either. Take a look at the "ORDER" directive.
  • OK, ORDER and specify the addr of the 1st should do it.
