MicroController Connection
Any one know how my program should be like when i need to pass in information for example "a" and display it in a display box... through serial communication.
  • know how to send 80h to the microcontroller and returning 55H??
  • MSDN has examples of serial communication programming on a Win32 platform.
    There are hundreds upon hundreds of Win32 programming websites on the internet, however Keil's Discussion Forum is not among them.
    My Usenet news server lists 2111 Microsoft-related newsgroups.
    Given all of that, I think your time would be much better spent inquiring about PC-related topics on PC-related venues, and not here, but that's just my opinion.
    This does, for a change, sound like an uC problem
    HOWEVER, we here are willing to HELP you, but not to do it for you.
    post YOUR code and help will be forthcoming.
  • "how to send 80h to the microcontroller"
    That is a PC programming excercise - eg, MSVC - for which you need to find a PC programming forum
    "and returning 55H??"
    Now you need a microprocessor system (both hardware and software) to receive the 80H and send a 55H.
    Look at the CSAMPLE example in your Keil\C51\examples\ folder - it illustrates receiving data and sending responses on the 8051 serial port.
  • erm... i did the codings... its like this...
    void CSerialComm::Send(HANDLE *pComm, CString str)
    	unsigned char StopByte=0x1;
    	unsigned long int n_out;
    	str = "0x80";
    	WriteFile(*pComm, str, str.GetLength(),&n_out , NULL);
    	WriteFile(*pComm, &StopByte, 1, &n_out, NULL);
    void CSerialComm::Receive(HANDLE *pComm, CString str1)
    	char cRxByte;
    	DWORD dwRead;
    	while(cRxByte!=0x1)
    		ReadFile(*pComm, &cRxByte, 1, &dwRead, NULL);
    		str1+=cRxByte;
    	MessageBox("Acknowledge Received");
    	//	MessageBox(str1);
    void CSerialComm::initComm(HANDLE *pComm)
    //	HANDLE hComm;
    //	hComm = CreateFile( "COM1:",
    //                    GENERIC_READ | GENERIC_WRITE,
    //                    0,
    //                    0,
    //                    OPEN_EXISTING,
    //                    FILE_FLAG_OVERLAPPED,
    //                  0);
    //	if (hComm == INVALID_HANDLE_VALUE)
       // error opening port; abort
    	*pComm = CreateFile("COM1:", GENERIC_WRITE|GENERIC_READ, 0, NULL, OPEN_EXISTING, 0, NULL);
    	if (*pComm ==INVALID_HANDLE_VALUE)
    		//MessageBox("Please input value !");
    	//FillMemory(&dcb, sizeof(dcb), 0);
    	dcb.DCBlength = sizeof(dcb);
    	dcb.BaudRate = CBR_9600;
    	dcb.fBinary = TRUE;
    	dcb.fDtrControl = DTR_CONTROL_DISABLE;
    	dcb.fRtsControl = RTS_CONTROL_DISABLE;
    	dcb.ByteSize = 8;
    	dcb.Parity = NOPARITY;
    	dcb.StopBits = ONESTOPBIT;
    	if (!SetCommState(*pComm, &dcb))
    		//MessageBox("Wrong Port");
    it can be executed without connecting the mc. but after the mc is connected, the program hangs
    can tell me wats wrong...
  • "tell me wats wrong..."
    You're asking in the wrong forum, that's what's wrong!
    That's PC code - so you need to ask about it in a PC forum!
    What have you done to debug it?
    MSVC includes a debugger!
  • Yes indeed it's the wrong forum. However I could send you a functionnal sample so at least you could try to solve your micro-controller communications problems with people sharing there knowledge on this forum (however HyperTerminal is enough for this purpose...). For this I need an e-mail.
    Jean-Pierre
