Hi, Using at89c51 i want some data to copy from program memory to external Data memory.. without using memcopy()... any idea ?
Since you evidently do not have the link to "the bible" here it is here are the links to "the bible" Chapter 1 http://www.semiconductors.philips.com/acrobat/various/80C51_FAM_ARCH_1.pdf chapter 2 http://www.semiconductors.philips.com/acrobat/various/80C51_FAM_PROG_GUIDE_1.pdf chapter 3 http://www.semiconductors.philips.com/acrobat/various/80C51_FAM_HARDWARE_1.pdf Erik
I have "the bible" and have for over 15 years. Answer my last question. What does PUSH read when you "PUSH P2". I'll save a post and lead to the next question, (assuming you answer): Q: How does one save the contents of P2? This is a common problem when the forground process uses P2 for movx a, @rn instructions, yet an interrupt routine expects to use P2 for other means (pdata access, for example). How does the interrupt routine save P2 (so it can later restore it of course)? As stated earlier, PUSH P2 is unreliable because, according to "the bible", it does not read the register.
Answer my last question. What does PUSH read when you "PUSH P2". Question is there a modify involved? Q: How does one save the contents of P2? with a shadow register Erik
with a shadow register Precisely!!! And this is why "INC P2" by itself doesn't work in the aforementioned model (where P2 is to be maintained across interrupts) ...as it MUST increment the shadow register before it increments P2.
"As stated earlier, PUSH P2 is unreliable because, according to "the bible", it does not read the register." I wonder if you can provide a page number to back that statement up?
I wonder if you can provide a page number to back that statement up? Intel-MCS51 Family-user manual.pdf Order No.:272383-002 February 1994 Page 3-9 Do I need to copy the entire page?
"Do I need to copy the entire page?" No, not at all. You just need to explain how it is relevant to the PUSH instruction.
No, not at all. You just need to explain how it is relevant to the PUSH instruction. Its relavent because "PUSH P2" doesn't necessarily push the value that's presently in the P2 output latch. Should I put up a short code example?
Precisely!!! And this is why "INC P2" by itself doesn't work in the aforementioned model (where P2 is to be maintained across interrupts) ...as it MUST increment the shadow register before it increments P2. This could have been umpteen posts shorter if you had introduced that you were discussing based on a shadow register earlier. There is, in most designs no shadow registers, only the few cases where interrupts handle ports pins that are also used in main are they used. You discussed this on the basis of P2 without even bringing in that a shadow register was used. Your initial statemnent "beware crossing page boundaries as "inc P2" won't necessarily produce what you expect" should have read "inc P2" can not be used when a shadow register is in use" and that statement is self-evident. Erik
This could have been umpteen posts shorter if you had introduced that you were discussing based on a shadow register earlier. There is, in most designs no shadow registers, only the few cases where interrupts handle ports pins that are also used in main are they used. You discussed this on the basis of P2 without even bringing in that a shadow register was used. Your initial statemnent "beware crossing page boundaries as "inc P2" won't necessarily produce what you expect" should have read "inc P2" can not be used when a shadow register is in use" and that statement is self-evident. That statement is not self-evident, its incorrect. On the contrary, the only way "inc P2" can safely be used IS with a shadow register technique. Thus, its not a discussion "based" on shadowing P2, rather I'm pointing out that shadowing P2 should be considered whenever P2 is manipulated. That's all I have to say on the matter for now.
That statement is not self-evident, its incorrect. On the contrary, the only way "inc P2" can safely be used IS with a shadow register technique Now it is getting ridiculous. Enough said Erik
Enough said Gosh...miracles DO happen.
Gosh...miracles DO happen. If you realized how ridiculous your statemet above is, now, THAT would be a miracle. Erik
If you realized how ridiculous your statemet above is, now, THAT would be a miracle. And where would we go from there? Why would it matter? To a stereotypicle forum alpha-nerd such as yourself, the goal is simply a daily victory. One doesn't have to read too many of these threads to realize this. BTW, the spelling error is intentional. I figured if nothing else, you could pick the reply apart based on that. (wait for it... wait for it...)
the goal is simply a daily victory I could not care less about a "victory". HOWEVER I do care about someone leading the novices astray with blatantly incorrect statements. Erik
