24-bit A/D converter noise free resolution help
hi,
i am developing a weigh scale application using Cirrus Logic 5532 24-bit ADC in unipolar mode.the output i am getting is very unstable (flickering on display). Can anybody please tell me how to get a stable count.
  • We use the same CS5532 for current measurement in battery management systems and I agree that its output might be very noisy. I use the upper 16 bits of the 24 bit AD-result and there's still noise.
    Noise depends on the hardware design (PCB Layout...). Don't use the same ground and supply for AD-converter and controller. The controller is very noisy, and that might also influence its supply.
    Before using software filtering (moving AVG), a hardware filter (i.e. anti aliasing filter) and perhaps a pre-amplifier (instrumention amplifier) is necessary.
  • Mine is a small budget project so i cannot invest in a DSP plus i have no prior experience in DSPs.
    1) there is no need for a DSP
    2) "limited budget" and "24bit ADC" - the joke of the year.
    You can NOT achieve anything above 14 bits without a 4 layer board, a chopper stabilized op-amp with expensive high precision resistors, a high precision voltage reference, an extremely quiet power supply ......
  • this is my first project ...
    Get an analog PCB layout book or you will never get anywhere with this.
  • First of all i would like to tell u that the problem was with power line noise rejection. I had wrongly configured the ADC for 60Hz noise rejection(7.5Sps OWR) instead of 50Hz noise rejection and corresponding OWR of 6.25Sps.The display is now much stable(+-1 weight).
    This really is my first project.
    i am only developing the software for the project invloving the interfacing of the uc with the ADC, display, keyboard and AT24C02 eeprom in C using keil C51 tools and hence wanted to how if any coding could control the flickering.
    i was not part of the pcb desinging and layout process.
    Why do you use the forum to tell micro something?
    now:
    earlier:
    my display is flickering in +/- 7 counts range with occasional surges
    do you still have the "occasional surges"?
