Error C213
In trying to compile the C code with the C51
compiler [Keil µvision2], I received error c213 "left side of asn-op not an lvalue" -
" the address of a changeable object is required at the right side of the
assignment operator". But i don't know where is/are problems...
Code:
#include <Chipcon\srf04\regssrf04.h>
#include <Chipcon\srf04\halsrf04.h>
#include <Chipcon\srf04\ebsrf04.h>
#include <ctype.h>
#define TX_entree 0x80 //P0.4
#define RI0 0x98
BYTE idata txBuffer[8];
BYTE idata buffer[8];
int i = 0;
int taille_tab;
void main () {
#ifdef STAND_ALONE
CLOCK_INIT();
IO_PORT_INIT();
#endif
ebLcdInit();
ebLcdUpdate("Emission test v0.1", NULL);
halWait(3000);
ebLcdUpdate("Initialisation", NULL);
halWait(2000);
halUartSetup(UART_BAUDRATE_115200, DEFAULT_MODE);
SPI_INIT(SCLK_6_MHZ);
POWER_UP_RESET_CCxxx0(); FIRST ERROR
UART_RX_ENABLE();
ebLcdUpdate("Reception et stockage des données en cours", NULL);
halWait(3000);
if(RI0 == 1){
//stockage des données
taille_tab = sizeof(buffer);
for (i = 1; i < taille_tab; i++) {
UART_WAIT_AND_RECEIVE(buffer[i]); SECOND ERROR IF I COMMENT THE FIRST
ebLcdUpdate("Emission des données en cours", NULL);
halWait(2000);
SPI_ENABLE();
halRfSendPacket(buffer, sizeof(buffer));
ebLcdUpdate("Fin", NULL);
halWait(2000);
Any help or comments appreciated. I'm workin' on the CC2500DK, it's an tranceiver HF and many fonctions has already created by the constructor.
John
  • we know Drew has written a WndProc
    Well, I will admit to having written a WndProc or two in my checkered past. Mostly I do embedded communications stuff not related to Windows, though. That sort of switch statement is a common pattern for me. That may just mean I'm in a rut, of course, but there always seems to be this pesky little bit of code to pull parameters out of a message and pass them to a routine.
    There's usually a function lying around in some module that does what you want, but is (and properly so) independent of the "control" layer that invokes it. Such a routine probably takes a couple of parameters. When the system is controlled by messages, those messages generally convey the same information, maybe in more generic units or more abstract format.
        case
            MsgA* msgA = (MsgA*)msg;
            SomeRoutine (msgA->a, msgA->b);
            break;
    You could write SomeRoutine(MsgA* msg), but then SomeRoutine depends on the message format. SomeRoutine (int a, int b) is independent of the management layer, but then you have this little stub of code to parse out parameters and call SomeRoutine(). If the code were more involved, there could be a ParseSomeParms(MsgA*) function that calls SomeRoutine, but that creates an extra function for every case, and often it's such a tiny bit of code that it seems unnecessary to declare a function just to get the local variable. So I use the local block.
    Sometimes I use them just to limit the scope of a variable, or get stack reuse (from compilers other than C51), or to delay declaration of a variable until I can initialize it. C99 and C++ allow you to move the actual declaration, but you can get much the same effect in ANSI C by introducing a local block to give you a place to declare variables again.
    And sometimes I even use them as comments, just to visually delimit a range of code where something is true, say a critical section.
    Lots of these uses are hints that you might want an actual function instead, but when the code is small, the code generator seems to prefer the programmer not to force it to move things into the proper registers for function calls, and pass parameters when it could just reference variables from the enclosing scope.
    Only the do..while() trick allows to put a ';' after the macro call without getting the if/else all messed up.
    My stylistic preference is never to have a "bare" single-statement if or else clause, for the sake of consistency and problem avoidance. (I've seen too many people pull their hair out after sticking a debug printf into their "one-line" if statement or adding a bit extra during maintenance and believing the indentation.) So I don't run into this particular limitation.
        if ()
            OneLinerCall();
        else
    expands into
        if ()
            // OneLiner was really a macro
        else
    so there's no dangling else. Without the exterior braces, though, the macro-with-braces is a disaster waiting to happen, and you'll need the do-while in the macro for grammatical purposes at the point of call.
    (I actually prefer the if-else-endif syntax as it neatly avoids the issue of null statements and dangling elses entirely, but c'est le C.)
  • "For the purposes of debugging, you should take your macro 'calls' and replace them with the individual construct. That is, put the defined do{}while(0); in the main code and try to compile it rather than using the macros."
    No, don't do that!
    You stand far more chance of messing it up in the process - or even inadvertently fixing a bug!
    Anyway, it's a waste of time - the preprocessor does all this for you anyway:
    Just use the .i file generated by the preprocessor, and inspect that.
    If you can't see the problem by inspection of the .i file, then just compile the .i file!
    See Andy's Handy Hint for Debugging Preprocessor Problems:
    http://www.8052.com/forum/read.phtml?id=29152
  • "Just use the .i file generated by the preprocessor, and inspect that."
    Some compilers have the option to retain comments in the .i file - which makes the inspection a whole lot easier.
    Unfortunately, Keil C51 does not have this option. :-(
  • Unfortunately, Keil C51 does not have this option. :-(
    But even so, you can have this cake and eat it, too. Just use a separate preprocessor (e.g. GCC's) with the right set of options that will let it mimic Keils' #include search mechanisms and predefined macros, instead of Keil itself.
