problem with flashing program
I buy the microcontroller XC866 with Keil uVision3 Software.
My problem:
I use the COM1 interface to flash code. The flashing program is 'LoaderV02F2.exe'
I run this program from command line (LoaderV02F2.exe code.hex f) - its working. But, I have to press OK button to download the code.
Therefore, I need flashing program, that don't require the user action (clicking on OK button)
Is there some (hidden) option disable the information window with OK and CANCEL button?, or some command line version of this program?
Than you for you answer.
Juraj Dudak
