If I configure the debug Initialization with DEBUG.INI which write " MAP 0x00010000, 0x00011FFF EXEC READ WRITE VNM MAP 0x10000000, 0x1001FFFF EXEC READ WRITE VNM MAP 0x30000000, 0x3001FFFF EXEC READ WRITE VNM " then at simulation analysis,when I choose the Debug->Memory Map……,the whole program will dead! I have test the problem, If the debug Initialization have configured the memory(like using MAP ……), then the Debug->Memory Map…… Dialogure will lead to the whole program dead!
Ok I get the problem, the VNM is an error in ExMEM congure in below, MAP 0x00010000, 0x00011FFF EXEC READ WRITE VNM delete VNM the program will be OK!
