Problem with Compiler/linker Generating code for indirect function pointers
void sys_startup_init(BOOL8 shutdown)
// Check for operating mode
if (!shutdown)
// setup MMU
shutdown = (*isys_startup_mmu_init)(shutdown);
// Shutdown if mode is not normal
The sys_startup_init function is entered from assembly code.
The code shutdown = (*isys_startup_mmu_init)(shutdown);
function pointer is where the code execution is incorrect.
Changing the function to :
void sys_startup_mmu_init(void)
results in the correct code being executed. However is not possible to change all the indirect function calls in this manner, so this is not a feasible solution.
C compiler version: 7.07h
