Problems with HELLO sample
I open the project, i start the simulator, but when i click on start/stop debugger,
a message follow:
*** error 65: access violation: addr=0x00000000
how can i correct start this simple little program?
the correct out should be : HELLO, but i can't see anything, only the error message
thanks!
  • You need to read the uVision Getting Started Guide - you can find it in the 'Books' window, or on the 'Help' menu.
    You should work through the example projects in it - they guide you through the whole process of creating a project, building it, running it in the simulator, and debugging it in the target.
    This will give you a proper introduction to the tools and how to use them.
    By working through the manual - rather than just jumping in - you will ensure that you don't miss some small but vital step and end up with an annoying error message...
