error 253
#include <reg52.h>
unsigned char chrState;
unsigned char chrDate[6];//year, month, date, hour, minute, second
unsigned char idata chrPlace;
void main()
unsigned char chrTemp;
do
do
}while(1);
switch (chrState)
case 1:
if (chrTemp<11)
switch (chrPlace)
case 8:
chrDate[0]%=10;
break;
case 7:
chrDate[0]/=10;
break;
case 6:
chrDate[1]%=10;
break;
case 5:
chrDate[1]/=10;
break;
case 4:
chrDate[2]%=10;
break;
case 3:
chrDate[2]/=10;
break;
case 2:
chrDate[3]%=10;
break;
case 1:
chrDate[3]/=10;
break;
case 16:
chrDate[4]%=10;
break;
case 15:
chrDate[4]/=10;
break;
case 14:
chrDate[5]%=10;
break;
case 13:
chrDate[5]/=10;
break;
default:
break;
break;
case 2:
break;
}while(1);
  • Please read the Notes at the top of the form where you typed your post - it tells you how to post code so that the layout is preserved.
    Please re-post the code, following the instructions - then it might be a bit more legible!
    Please also post the full text of the error message.
    The Manuals contain lists with descriptions of the error messages - have you looked at them?
  • You're missing some code:
    do
        do
        }while(1);
    Most of the posted sample is unreachable.
    I'd also suggest that the code might be a little more compact and readable if you set an index and an operator, so that it all collapses into
    typedef enum {Mod, Div } Operators;
    Operators op = SomeFunctionOfState (chrState);
    U8 i = SomeOtherFunctionOfState (chrState);
    if (op == Mod)
        chrDate[i] %= 10;
    else
        chrDate[i] /= 10;
