ISD51 has a problem
I have a problem using ISD51 to debug my code. AT first, I used the simulator to run my code and it works fine. Then I added ISD51.A51 into my project and also added ISDinit() and ISDcheck() to my code, changed the OPTION menu to enable ISD51 and compiled. The problem is that the code doesn't start running after loading (seems waiting). Can anyone help with it?
Another thing: during compiling, I saw there were a few bytes overlap in code space. Does it matter?
Frank
compiling LOG.C...
compiling test.c...
assembling Conf_tny.a51...
assembling STARTUP.A51...
assembling ISD51.A51...
linking...
*** WARNING L5: CODE SPACE MEMORY OVERLAP
TO: 0025H
Program Size: data=68.3 xdata=454 code=16180
creating hex file from ".\output\snake"...
".\output\snake" - 0 Error(s), 1 Warning(s).
