Hi is there anyway of knowing if the LPC is receiving pulses on its INT0 pin. I have it already set up like this: IT0 = 1; //Pulses are edge detected EX0 = 1; //interrupt enable bit EA =1; It works fine, but is there anyway to find out if the pulses have stopped coming into this pin? The time the pulses will be present at this pin is unknown. This message is also posted at http://www.8052.com/forum/post.phtml
Drew Davis I made the changes you posted. It still does not work. I tried it with emulator and it single steps, jumps into the ISR, reloads the timer, but does not clear TF0 flag bit. It increments the sec_counter variable once though. Did you try it yourself. did it work for you. I tried with the actual chip LPC932 revision F and it did not work...I say that because it did not turn on P2 LED's. What would be the next step. #include <Reg932.h> #include <stdio.h> #include <intrins.h> void init(void); void brkrst_init(void); void Time_Base(void); void T0_Start(void); unsigned int Sec_Counter = 0; void Main(void) { P2 = 0x00; P0 = 0x00; init(); // configure ports brkrst_init(); //enable UART break detect Time_Base(); } void init(void) { P0M1 = 0x00; P0M2 = 0xCD; // Quasi-bidirectional P1M1 = 0x00; // Push-pull P1M2 = 0xFF; P2M1 = 0x00; // push pull output P2M2 = 0xFF; P1M1 |= 0x18; // make INT0 and INT1 input pins P1M2 &= 0xE7; ES = 1; // enable UART interrupt EA = 1; } void brkrst_init(void) // This function allows ISP entry through the UART break detect { SCON = 0x50; // select the BRG as UART baud rate source, pg. 60 SSTAT = 0x00; //Timer1 BRGR0 = 0xF0; // 9600 BAUD at @ 7.373MHz internal RC oscillator BRGR1 = 0x02; //timer increments every .0271 microsec. BRGCON = 0x03; // enable BRG, pg. 59 AUXR1 |= 0xC0; // enable reset on break detect, pg. 102 } void UART(void) interrupt 4 //Interrupt number for serial port { RI = 0; // clear receive interrupt flag } void Time_Base(void) { ET0 =1; TR0 = 0; TMOD |= 0x01; TAMOD = 0x00; T0_Start(); EA = 1; TR0 = 1; } void timer(void) interrupt 1 using 1 { T0_Start(); // start timer again Sec_Counter++; if (Sec_Counter == 20) // if 1 sec have passed { Sec_Counter = 0; P2 = 0xFF; TR0 = 0; } } void T0_Start (void) { TH0 = (65536-30720)/256; // 34816 TL0 = (65536-30720)%256; // .2 TF0 = 0; }
The ISR needs to clear the overflow flag (TF0) so that the interrupt can re-occur no need, quoting "the bible" Cleared by hardware as the program vectors to the interrupt routine. Erik
Erik, TF0 could be cleared by software as well...But can any one try it on his simulator or emulator...please. Thank you
void Main(void) { P2 = 0x00; P0 = 0x00; init(); // configure ports brkrst_init(); //enable UART break detect Time_Base(); } What do you think happens after the call to Time_Base()? Stefan
