How to fine tune a piece of C code into macro?
I have a piece of C code,
if(u3Varaible0 > u3Variable2)
#ifdef DEF_SOMETHING
#else
#endif
else
The variable length of u3Varaible0 is 3 bytes. I don't want to declare it as "unsigned long"(inorder to save onchip memory and reduce execution cycles), So I have to write this piece C code into asm code look like
CLR C
MOV Au3Varaible0_L
SUBB A,u3Variable2_L
MOV Au3Varaible0_M
SUBB A,u3Variable2_M
MOV Au3Varaible0_H
SUBB A,u3Variable2_H
JC C0049
C0049:
I want it be a macro(inorder to reduce execution cycles).
But now comes the problem:
1.
If I write this code as a asm macro in an asm source. I just can't use this macro from a C code.
2.
If I try to write is as C macro using #define, It is impossible to use inline assembly in the macro!!
3.
will also cause an error in #define macro
Does anyone know another good way to solve this fine tune problem?
  • If this is a real problem to you, then you should be writing in assembler anyway.
    I do not know what is happening, but recently there has been a swarm of posts "why can C not do what assembler can".
    Hey Guys, if you want the pleasure of C, do not complain about the pain.
    It is emminently possible and practical to mix C and assembler files but do not attempt to mix C and assembler statements
  • Erik said,
    "It is emminently possible and practical to mix C and assembler files, but do not attempt to mix C and assembler statements"
    An excellent way of putting it!
