uVision2 MENU: DEBUG/Memory Map I have to re-enter the memory map every time I go into debug with the below information. With Read and Write check boxes checked. X:0x100000,X:0x10FFFF X:0x180000,X:0x18FFFF X:0x080000,X:0x08FFFF X:0x010000,X:0x010000 When I quit debug and start debug again it's gone and I have to re-enter it again. Where can I put this so it's already defined when I go into debug so I don't have to keep typing it in. Thanks,
Look on the 'Debug' tab of your Project options - There's an 'Initialisation File' box. That's the way to do it!
Thanks for the help, it worked. This is what I entered into the debug.ini file.
MAP X:0x100000,X:0x10FFFF READ WRITE MAP X:0x180000,X:0x18FFFF READ WRITE MAP X:0x080000,X:0x08FFFF READ WRITE MAP X:0x010000,X:0x010000 READ WRITE
