Large memcpy
We are using Keil C-51 V7.06.
There is a structure defined:
typedef struct
  unsigned char address_bus_h;
  unsigned char address_bus_l;
  unsigned char data_bus;
}instbus_raw_t;
Using three simple lines to copy the structure to another it enlarges code by 9 bytes, but this is not an elegant solution:
instbus_raw.address_bus_h = instbus_raw_local.address_bus_h;
instbus_raw.address_bus_l = instbus_raw_local.address_bus_l;
instbus_raw.data_bus = instbus_raw_local.data_bus;
Using the normal library function memcpy
blows up the code by 300 bytes!
memcpy(&instbus_raw,&instbus_raw_local,sizeof(instbus_raw_t));
Using an own function my_memcpy the code increases by 167 bytes:
void *(my_memcpy)(void *s1, const void *s2, size_t n)
  char *su1 = (char *)s1;
  const char *su2 = (const char *)s2;
  for (; 0 < n; --n)
    *su1++ = *su2++;
  return (s1);
my_memcpy(&instbus_raw,&instbus_raw_local,sizeof(struct instbus_raw_t));
In a project with a little chip of 2k Flash, 300 bytes for copying few bytes are considerable!
Does anyone remarking same effects with library functions wasting resources?
Regards Peter
  • "Or am I too picky?"
    You're too picky.
    In my opinion:
    If you have to use assembler rather than 'C' for reasons of code size or speed then you're using the wrong hardware. The only case I can really see for using assembler is when you need to make sure the code doesn't change across compiler versions.
  • Yes, I agree, statements like these have to be supported by facts. I use the C166 compiler, and there are not too many compilers for that architecture. And from what I heard Keil's C166 is the best available.
    But what I meant was that so many times when I look at the code generated by C166 I can't help but notice so obvious optimizations not performed by the compiler. Let's look at a real-world example:
    #include <intrins.h>
    long l[2];
    long read_long_atomically(int i)
        long tmp;
        long *ptr;
        ptr = &l[i];
        _atomic_(0);
            tmp = *ptr;
        _endatomic_();
        return tmp;
    Compiler listing:
    MOV       R5,R8
    SHL       R5,#02H
    MOV       R4,#l
    ADD       R4,R5
    ATOMIC    #02H
    MOV       R6,[R4]
    MOV       R7,[R4+#02H]
    MOV       R4,R6
    MOV       R5,R7
    RET
    Quite a few temporary storage registers can be eliminated in this code. It would not be unreasonable to expect the following kind of code from a modern compiler:
    SHL       R8,#4
    ADD       R8,#l
    ATOMIC    #02H
    MOV       R4,[R8]
    MOV       R5,[R8+#2]
    RET
    That's what I meant really.
    - mike
  • In this case, I agree with you. However, most functions are not quite that trivial.
    It's easy to create the perfect optimizing compiler if you guarantee that all function it compiles are small and are not too complex.
    The problem arises when you have functions that are insanely complex. Then, the compiler still must do a good job.
    As it is, the small functions like you demonstrate would be the ones that I would first write in C (to get working) and later go back in write in assembly (if needed).
    Jon
  • "If you have to use assembler rather than 'C' for reasons of code size or speed then you're using the wrong hardware."
    As I've said before, all generalisations are bad! ;-)
    IF you are making extremely cheap products in extremely large volumes, the development costs are secondary to the component costs.
    In such cases, you want the cheapest processor you can possibly find - and you can afford to put in a bit more development effort to squeeze the last ounce of performance, or shoe-horn the code into the smallest possible ROM.
    However, I do agree that most of the questions here about inline assembler are due to misconceptions...
  • The only case I can really see for using assembler
    Sometimes you need to poke around in assembler for some glue logic in startup code before main can even get going. Say, boot code loading an application and restarting into it, or initializing bank switch logic, or that sort of thing. C presumes a certain environment exists, and somethings you need to do things outside of that world's "laws of physics".
    Other times, you might need assembler to cope with some picky hardware. C doesn't always give you precise control over which bits change at which address on which clock cycle.
    Speed and efficiency count, too. Often, there's just a couple of routines that can greatly benefit from specialized assembler, and just throwing a bigger processor at the whole project for the sake of a couple of functions is not really the right answer.
  • It's easy to create the perfect optimizing compiler if you guarantee that all function it compiles are small and are not too complex.
    I'm sure a lot of users would appreciate a compiler command line option called "perform near-perfect optimization on simple functions". If it's easy, why not do that?
    I seem to remember that the OpenWatcom compiler even allows the user to specify the amount of virtual memory to use in optimization. Basically the amount of available memory pretty much determines how good a job the compiler does at optimizing complex functions.
    Ah, well...
    - mike
  • "Sometimes you need to poke around in assembler for some glue logic in startup code before main can even get going."
    Sure, sorry, my comments were really in the context of calling hand optimised assembler routines from 'C'.
    "Other times, you might need assembler to cope with some picky hardware. C doesn't always give you precise control over which bits change at which address on which clock cycle."
    Well, I'd argue that this sort of thing shouldn't be done in software - chuck in a PLD or some such to move the timing burden to hardware.
    "Speed and efficiency count, too. Often, there's just a couple of routines that can greatly benefit from specialized assembler, and just throwing a bigger processor at the whole project for the sake of a couple of functions is not really the right answer."
    Yes, but as we've seen in this thread the speed and efficiency gains can often be made by rewriting [an existing library function, say] code in 'C' - there may be little to be gained from the move to assembler.
    Outwith minor modifications to startup.a51 I can only think of one occasion I've had to use assembler on the 8051, and that was to call functions in an on-chip bootloader that required certain values in certain registers. While it was possible to do it in 'C' it fitted into the 'maintain the same code across compiler versions' category.
    I also take Andy's point about low value high volume product, I've always been fortunate enough to work on high value kit where component cost isn't much of an issue, so I tend to overlook this.
  • "I also take Andy's point about low value high volume product, I've always been fortunate enough to work on high value kit where component cost isn't much of an issue, so I tend to overlook this."
    Actually, so do I!
    But I've been picked up on it a number of times now, so I thought I'd just get my own back! ;-)
  • In compact_memcpy, shouldn't R6 only be pre-incremented if R7 is non-zero?
  • Bill, I think you may well be right. Thanks.
