Global & Static initialization problem
I am developing a firmware for EZUSB FX based board. I am facing a small problem. I am not able to initialize a Global variable in my firmware. Even though I assign the global variable with 0 initial value, But the variable does not take that value. I am using SMALL memory model for my development.
my declerations looks like this :-
BYTE GlobalCount = 0;
and in my sof() I am using this variable and updating it and reusing it again in next sof().
Please advise ..
Rahul Gupta
  • Reduce your code to the minimum complete program that exhibits the problem then post it here.
    Until then we are fishing in the dark.
  • here is the code ..
    //FW.C
    #include "ezusb.h"
    #include "ezregs.h"
    // Global Variables
    volatile BOOL	GotSUD;
    BOOL		Rwuen;
    BOOL		Selfpwr;
    volatile BOOL	Sleep;
    WORD	pDeviceDscr;	// Pointer to Device Descriptor; Descriptors may be moved
    WORD	pConfigDscr;
    WORD	pStringDscr;
    extern  BYTE glbCntW;
    // Code --
    // Task dispatcher
    void main(void)
    	DWORD	i;
    	WORD	offset;
    	DWORD	DevDescrLen;
    	DWORD	j=0;
    	WORD	IntDescrAddr;
    	WORD	ExtDescrAddr;
    	Sleep = FALSE;
    	Rwuen = FALSE;
    	Selfpwr = FALSE;
    	GotSUD = FALSE;
    	// Initialize user device
    	TD_Init();
    	pDeviceDscr = (WORD)&DeviceDscr;
    	pConfigDscr = (WORD)&ConfigDscr;
    	pStringDscr = (WORD)&StringDscr;
    	if ((WORD)&DeviceDscr & 0xe000)
    		IntDescrAddr = INTERNAL_DSCR_ADDR;
    		ExtDescrAddr = (WORD)&DeviceDscr;
    		DevDescrLen = (WORD)&UserDscr - (WORD)&DeviceDscr + 2;
    		for (i = 0; i < DevDescrLen; i++)
    			*((BYTE xdata *)IntDescrAddr+i) = 0xCD;
    			*((BYTE xdata *)IntDescrAddr+i) = *((BYTE xdata *)ExtDescrAddr+i);
    		pDeviceDscr = IntDescrAddr;
    		offset = (WORD)&DeviceDscr - INTERNAL_DSCR_ADDR;
    		pConfigDscr -= offset;
    		pStringDscr -= offset;
    	EZUSB_IRQ_ENABLE();				// Enable USB interrupt (INT2)
    	EZUSB_ENABLE_RSMIRQ();
    	PORTCCFG |= 0xc0;
    	USBBAV = USBBAV | 1 & ~bmBREAK;
    	USBIEN |= bmSUDAV | bmSUTOK | bmSUSP | bmURES;
    	EA = 1;
       #ifndef NO_RENUM
       EZUSB_Discon(TRUE); // Renumerate
       #endif
    	CKCON = (CKCON&(~bmSTRETCH)) | FW_STRETCH_VALUE; // Set stretch to 0 (after renumeration)
    	// Task Dispatcher
    	while(TRUE)					// Main Loop
    		if(GotSUD)				// Wait for SUDAV
    			SetupCommand();	 		// Implement setup command
      			GotSUD = FALSE;		   	// Clear SUDAV flag
    		if (Sleep)
        		if(TD_Suspend())
        		    Sleep = FALSE;	   	    		    do
           			    EZUSB_Susp();	    		        }
                    while(!Rwuen && EZUSB_EXTWAKEUP());
        			EZUSB_Resume();	// If source is the Wakeup# pin, signal the host to Resume.
        			TD_Resume();
    		TD_Poll();
    void SetupCommand(void)
    	void	*dscr_ptr;
    	DWORD	i;
    	switch(SETUPDAT[1])
    		case SC_GET_DESCRIPTOR:					if(DR_GetDescriptor())
    				switch(SETUPDAT[3])
    					case GD_DEVICE:
    					SUDPTRH = MSB(pDeviceDscr);
    					SUDPTRL = LSB(pDeviceDscr);
    						break;
    					case GD_CONFIGURATION:			// Configuration
    						if(dscr_ptr = (void *)EZUSB_GetConfigDscr(SETUPDAT[2]))
    							SUDPTRH = MSB(dscr_ptr);
    							SUDPTRL = LSB(dscr_ptr);
    						else
    							EZUSB_STALL_EP0(); 	// Stall End Point 0
    						break;
    					case GD_STRING:				// String
    						if(dscr_ptr = (void *)EZUSB_GetStringDscr(SETUPDAT[2]))
    								STRINGDSCR *sdp;
    	BYTE len;
    							sdp = dscr_ptr;
    							len = sdp->length;
    							if (len > SETUPDAT[6])
    								len = SETUPDAT[6]; //limit to the requested length
    							while (len)
    								for(i=0; i<min(len,64); i++)
    									*(IN0BUF+i) = *((BYTE xdata *)sdp+i);
    								//set length and arm Endpoint
    								EZUSB_SET_EP_BYTES(IN0BUF_ID,min(len,64));
    								len -= min(len,64);
                            (BYTE *)sdp += 64;
    								// Wait for it to go out (Rev C and above)
    								while(EP0CS & 0x04)
    							EZUSB_SET_EP_BYTES(IN0BUF_ID,0);
    													EP0CS = bmHS;						}
    						else
    						break;
    					default:				// Invalid request
    			break;
    		case SC_GET_INTERFACE:						// *** Get Interface
    			DR_GetInterface();
    			break;
    		case SC_SET_INTERFACE:						// *** Set Interface
    			DR_SetInterface();
    			break;
    		case SC_SET_CONFIGURATION:					// *** Set Configuration
    			DR_SetConfiguration();
    			break;
    		case SC_GET_CONFIGURATION:					// *** Get Configuration
    			DR_GetConfiguration();
    			break;
    		case SC_GET_STATUS:						// *** Get Status
    			if(DR_GetStatus())
    				switch(SETUPDAT[0])
    				case GS_DEVICE:				// Device
    						IN0BUF[0] = ((BYTE)Rwuen << 1) | (BYTE)Selfpwr;
    						IN0BUF[1] = 0;
    						EZUSB_SET_EP_BYTES(IN0BUF_ID,2);
    						break;
    					case GS_INTERFACE:			// Interface
    						IN0BUF[0] = 0;
    						IN0BUF[1] = 0;
    						break;
    					case GS_ENDPOINT:			// End Point
    					IN0BUF[0] = EPIO[EPID(SETUPDAT[4])].cntrl & bmEPSTALL;
    						IN0BUF[1] = 0;
    						break;
    					default:				// Invalid Command
    			break;
    		case SC_CLEAR_FEATURE:						// *** Clear Feature
    			if(DR_ClearFeature())
    			switch(SETUPDAT[0])
    				case FT_DEVICE:				// Device
    						if(SETUPDAT[2] == 1)
    							Rwuen = FALSE; 		// Disable Remote Wakeup
    						else
    						break;
    					case FT_ENDPOINT:			// End Point
    						if(SETUPDAT[2] == 0)
    						EZUSB_UNSTALL_EP( EPID(SETUPDAT[4]) );
                         EZUSB_RESET_DATA_TOGGLE( SETUPDAT[4] );
    					else
    						break;
    			break;
    		case SC_SET_FEATURE:						// *** Set Feature
    			if(DR_SetFeature())
    				switch(SETUPDAT[0])
    							Rwuen = TRUE;		// Enable Remote Wakeup
    						else
    						break;
    							EZUSB_STALL_EP( EPID(SETUPDAT[4]) );
    						else
    						break;
    			break;
    		default:						if(DR_VendorCmnd())
    			EZUSB_STALL_EP0();
    	// Acknowledge handshake phase of device request
    	// Required for rev C does not effect rev B
    	EP0CS |= bmBIT1;
    void resume_isr(void) interrupt WKUP_VECT
    	EZUSB_CLEAR_RSMIRQ();
    Please advise !! (I can mail you the project, if that helps !! pls gimme you mail id)
    Rahul
  • #pragma NOIV // Do not generate interrupt vectors
    #include <ezusb.h>
    #include <ezregs.h>
    #include <stdio.h>
    #include <stdlib.h>
    #include <string.h>
    #define DCM_SIZE 64
    #define XBYTE ((unsigned char volatile xdata*) 0)
    extern BOOL GotSUD;
    extern BOOL Sleep;
    extern BOOL Rwuen;
    extern BOOL Selfpwr;
    BYTE Configuration;
    BYTE AlternateSetting;
    volatile BYTE glbISOCnt =0 ;
    volatile BYTE glbCnt=0;
    static BYTE glbCntW = 0;
    volatile BYTE iso_out_cnt =0;
    unsigned char *pBuffer;
    unsigned char *CntBuf;
    // Task Dispatcher hooks
    void TD_Init(void) // Called once at startup
    USBIEN |= bmSOF + bmURES;
    INISOVAL = bmEP8; //+bmEP9;
    OUTISOVAL = bmEP8;
    IN8ADDR = 0x50;
    OUT8ADDR = 0x00;
    void TD_Poll(void) // Called repeatedly while the device is idle
    BOOL TD_Suspend(void) // Called before the device goes into suspend mode
    return(TRUE);
    BOOL TD_Resume(void) // Called after the device resumes
    return(TRUE);
    // Device Request hooks
    // The following hooks are called by the end point 0 device request parser.
    BOOL DR_GetDescriptor(void)
    return(TRUE);
    BOOL DR_SetConfiguration(void) // Called when a Set Configuration command is received
    Configuration = SETUPDAT[2];
    return(TRUE); // Handled by user code
    BOOL DR_GetConfiguration(void) // Called when a Get Configuration command is received
    IN0BUF[0] = Configuration;
    EZUSB_SET_EP_BYTES(IN0BUF_ID,1);
    BOOL DR_SetInterface(void) // Called when a Set Interface command is received
    AlternateSetting = SETUPDAT[2];
    BOOL DR_GetInterface(void) // Called when a Set Interface command is received
    IN0BUF[0] = AlternateSetting;
    BOOL DR_GetStatus(void)
    return(TRUE);
    BOOL DR_ClearFeature(void)
    return(TRUE);
    BOOL DR_SetFeature(void)
    return(TRUE);
    BOOL DR_VendorCmnd(void)
    return(FALSE);
    // USB Interrupt Handlers
    // The following functions are called by the USB interrupt jump table.
    // Setup Data Available Interrupt Handler
    void ISR_Sudav(void) interrupt 0
    GotSUD = TRUE; // Set flag
    EZUSB_IRQ_CLEAR();
    USBIRQ = bmSUDAV; // Clear SUDAV IRQ
    // Setup Token Interrupt Handler
    void ISR_Sutok(void) interrupt 0
    EZUSB_IRQ_CLEAR();
    USBIRQ = bmSUTOK; // Clear SUTOK IRQ
    void ISR_Sof(void) interrupt 0
    BYTE i = 0;
    BYTE h = 0 , l = 0;
    iso_out_cnt = 0;
    h = OUT8BCH;
    l = OUT8BCL;
    if (l)
    iso_out_cnt = (WORD) h;
    iso_out_cnt <<= 8;
    iso_out_cnt += l;
    iso_out_cnt = OUT8BCL;
    if (iso_out_cnt > 0)
    glbISOCnt = iso_out_cnt;
    if (iso_out_cnt)
    else
    for (i=0;i<glbISOCnt;i++)
    IN8DATA = glbCntW;
    glbCntW = glbCntW + glbISOCnt;
    if (glbCntW == glbISOCnt * 4)
    glbCntW = 0;
    EZUSB_IRQ_CLEAR();
    USBIRQ = bmSOF; // Clear SOF IRQ
    void ISR_Ures(void) interrupt 0
    EZUSB_IRQ_CLEAR();
    USBIRQ = bmURES; // Clear URES IRQ
    void ISR_Susp(void) interrupt 0
    Sleep = TRUE;
    EZUSB_IRQ_CLEAR();
    USBIRQ = bmSUSP;
    Along with these 2 files I am including
    ezusb.lib, USBJMP.obj, STATUP.A51, INIT.A51(provided by cypress).
    Rahul
  • ///////Periph.c
    #include <ezusb.h>
    #include <ezregs.h>
    #include <stdio.h>
    #include <stdlib.h>
    #include <string.h>
    #define DCM_SIZE 64
    extern BOOL GotSUD;
    extern BOOL Sleep;
    extern BOOL Rwuen;
    BYTE Configuration;
    OUTISOVAL = bmEP8;
    IN8ADDR = 0x50;
    OUT8ADDR = 0x00;
    return(TRUE);
    return(TRUE);
    return(TRUE);
    return(TRUE);
    return(TRUE);
    return(TRUE);
    return(FALSE);
    EZUSB_IRQ_CLEAR();
    EZUSB_IRQ_CLEAR();
    BYTE i = 0;
    BYTE h = 0 , l = 0;
    iso_out_cnt = 0;
    h = OUT8BCH;
    l = OUT8BCL;
    if (l)
    iso_out_cnt <<= 8;
    iso_out_cnt += l;
    if (iso_out_cnt)
    else
    IN8DATA = glbCntW;
    glbCntW = 0;
    EZUSB_IRQ_CLEAR();
    EZUSB_IRQ_CLEAR();
    Sleep = TRUE;
    EZUSB_IRQ_CLEAR();
    USBIRQ = bmSUSP;
    Rahul
  • The code you have posted #includes files I don't have, calls functions that aren't defined and runs on hardware I don't have.
    You need to strip the program right down to a main function, ISR and variable declarations. If that still doesn't work, post it. If it does work, add your other code back in bit by bit until the problem reappears. You will then have a pretty good idea where the problem lies.
  • This code is taken from an example supplied with the Cypress development toolkit. I have only changed the code in Sof() function. The main functions etc .. is the minimal code for initialization and support for a ISO endpoint and bringing up the board.
    Rahul
