Hi, I need to know the specs. of the C language.I have a few books on C but does anyone have a link/soft copy/forums. Rgds Raj Shetgar
"The curren C standard is available as an electronic document from Techstreet at 18 USD" Cheaper than Hitex, then! ;-)
"The curren C standard is available as an electronic document from Techstreet at 18 USD" I couldn't see 'C' for download - only C++. Can you give a direct link?
Different beasts. The Hitex one is the C90+A1 (ie C95) Which most embedded compilers work to. It is in hard copy. the techstret one is the US version and is a PDF
http://www.techstreet.com/cgi-bin/new_results?searchText=9899&searchType=keyword&newSearch=1&sort=rel&submit.x=37&submit.y=12 you should search by the C standard number 9899
"you should search by the C standard number 9899" I tried that, but couldn't see it before. But now I can - thanks! For under a tenner, I might as well get the C++ one as well!
The draft might still be available but it is inaccurate as there were changes between the final public draft and the issued standard
