PORT6 momentary pulled low during Reset
I am running an application where an external reset from a WDT generates a reset on an ST10F168. When the reset occurs, all of PORT6 on the device is momenterally pulled low, then is pulled high again. There is no obviouse reason for this, and it is causing a major problem. The particular problem is with P6.5, which has an external pull up.
Any help would be appreciated.
Joe
