Why does the Keil compiler generate bad code for the DS400C80?
The following code:
fwsUniChar c;
fwsUniChar *temp;
temp=p->inPtr;
c = *temp;
temp++;
p->inPtr = temp;
correctly increments the pointer p by 0x01
instead of
fwsUniChar c = p->inPtr++;
which incorrectly increments the pointer p by 0x101
This code compiles and runs correctly with ANSI C compilers
Also
routine1() reentrant
enum ElementTagType type;
routine2(&type);
routine2(enum ElementTagType *type)
type = START_TAG;
does not work (i.e. type in routine1 is not set to START_TAG after calling routine 2.
There is a default XBPSTACK
Any Ideas
Barry
