XC161CJ and I2C
Hi Everybody,
I'm experimenting with Infineon's XC161CJ-controller on an Infineon SK-XC16x starter kit. Most of my routines work now, except the I2C-routines. Sending of data works OK, but the errors occur when I want to receive data.
Has anybody on this forum written I2C-routines for this controller? And if so, are you willing to share them?
Thanks in advance. :)
Kind Regards,
Dennis Ebben
  • I am also looking for I2C drivers for the Infineon XC16x or information on creating these drivers. Any help would be greatly appreciated.
    rford(a)ranfo.com
  • Hello,
    I will send it in some minutes.
    Stefan
  • Hi Stefan,
    I'm working on a project with the XC167 and looking for suggestions how to handle i2c communication with a 24LC256.
    I've been using:
    http://www.keil.com/download/docs/xc16x_i2c_ex.zip.asp
    but when I try to add 'acknowledge polling' to the writing of a page (64 bytes) I didn't success.
    Do you use 'acknowledge polling' in your example?
    If so, could you please send me your sources too.
    Please send it to langles@sasistel.es
    Thank you very much.
  • Hi Stefan,
    I've been using:
  • Hey LluĂ­s,
    I have the same setup af you, but using the XC-161CJ.
    I have also use the source code that You refer to.
    But I have problems with the
    read
    routine. I have not succeded to send the
    RSC
    , that is the Repeated Start Condition with the following EEPROM Address. Did you succed to communicate with this 24LC256. Best Regards Henrik Green
  • Hi Henrik
    This is the software I finally succeed. I don't remmember exactly what I did but here you have it
    Best Regards
    Lluìs
    void I2C_vEndTrans ()
    I2C_vGenStopCond (); // Generate Stop (Clear BUM)
    I2C_ubResetStatus (I2C_IRQD | I2C_IRQP | I2C_IRQE); // Clear IRQD, IRQP, IRQE
    while (I2C_uwGetStatus () & I2C_BB); // Wait for Idle Bus
    ubyte I2C_ubCheckEnd ()
    delay (1);
    while ((I2C_uwGetStatus () & I2C_IRQD) == 0x0000); // Wait for end of TX (IRQD)
    if (I2C_uwGetStatus () & I2C_LRB) return 1; // Check for ACK (LRB)
    return 0;
    void I2C_vWaitRx ()
    delay (1);
    while ((I2C_uwGetStatus () & I2C_IRQD) == 0x0000); // Wait for end of RX (IRQD)
    ubyte I2C_EEPRD (uword add, uword *dat)
    if (I2C_uwGetStatus () & I2C_BB) return EEP_BUSY; // Check if Bus is busy (BB)
    I2C_ubResetStatus (I2C_AL | I2C_IRQD | I2C_IRQP | I2C_IRQE); // Reset Status Register
    add <<= 1; // Convert address of word to address of byte
    I2C_vGenStartCond (); // Generate Start (Set BUM) START
    I2C_vWriteData ((EEPDEVADD << 1) | WRBIT); // Write Slave Address and WR CONTROL WRITE
    if (I2C_ubCheckEnd ()) {I2C_vEndTrans (); return EEP_NOTOK;} // Check for ACK ACK
    I2C_vWriteData (HIGHBYTE (add)); // Write Address (High Byte) ADDRESS HIGH
    I2C_vWriteData (LOWBYTE (add)); // Write Address (Low Byte) ADDRESS LOW
    I2C_vGenRSC (); // Repeated Start (Set RSC) START
    I2C_vWriteData ((EEPDEVADD << 1) | RDBIT); // Write Slave Address and RD CONTROL READ
    I2C_vSetDataDirRx (); // Disable (Tx (Clear TRX)
    I2C_vEnableACK (); // ACK for all bytes except last one
    I2C_uwReadData (); // Start Rx Clock
    I2C_vWaitRx (); // Wait Low Byte received
    I2C_vDisableACK (); // NACK for last byte
    I2C_vStopAfterTransmission (); // Generate Stop after Rx (Set STP)
    *dat = I2C_uwReadData (); // Read Low Data Byte and Start new Rx Clock
    I2C_vWaitRx (); // Wait High Byte Received
    *dat |= I2C_uwReadData () << 8; // Read High Data Byte
    I2C_vEndTrans (); // Wait End transmission
    return EEP_OK; // Done
    ubyte I2C_ubAckPoll ()
    ubyte i, s;
    s = 1;
    for (i = 0; i < 20; i++)
    delay (2000); // don't stress the 24LC256
    if (!I2C_ubCheckEnd ()) {s = 0; break;} // If ACK then writing is done
    return s;
    ubyte I2C_EEPWR (uword add, uword *dat, ubyte cnt)
    ubyte i;
    if (!cnt) return EEP_OK; // Nothing to write
    add <<= 1;
    for (i = 0; i < cnt; i++) // For each data byte
    I2C_vWriteData (LOWBYTE (*dat)); // Write Low Data Byte
    I2C_vWriteData (HIGHBYTE (*dat)); // Write High Data Byte
    if (I2C_ubAckPoll ()) {I2C_vEndTrans (); return EEP_NOTOK;} // Check Acknowledge polling
  • Hi Everyone,
    I am having trouble also reading a 24LC04B/P connected to XC167-32 via the I2C.
    Is it possible for someone to send me the driver that has been bouncing around Europe down here to Australia.
    mark.bozovic[at]dtsysint[dot]com
    Danker/Tack/Gracias/Hvala
    Mark..
  • Hi,
    Am working with XC167CI-16F, am trying to read sonar sensors SRF08 via I2C bus, and I used the code used for eeprom in keil's website but I still have problem that I cant read this sensor while I need to read it ... I dont want to write on it ... at least I need to read that sonar...
    Please help me and thanks..
    I.J
  • Hello Stefan,
    could you send me the IIC Routines also to
    erik.vischer@siemens.com
    Thank you.
    Best Regards
  • Does anyone have a copy of Stefans I2C code?
    If so, could you please send it to: kgott@sciton.com.
    Thanks!
  • I am working with an XC167 PhyCore module in a battery management system for an electric vehicle and have the same problem. The KEIL code is very close to accurate. The waveforms on the output look correct during write, however read hangs after the first byte.
    Does anyone have a working low-level driver for the XC167 IIC module? Or maybe just an explanation of the sequence you go through to send and receive bytes with the IIC?
    Thanks in advance.
    Terry Hansen
    AEV
  • I have a project (XC167) that I created some time ago to communicate via I2C to a SRF08 sensor (polled) and then send the results out the serial port. If interested post your email address and I will send it to you.
    -Chris
  • Great!
    terry.hansen@aevehicles.com
    Thanks for the help.
