Bitwise logical AND stores in a bit ....
I get a curious result when compiling such a following code :
typedef union  {
  unsigned char                cCtrlFullByte;
  struct {
    unsigned char  bEnable          : 1;
    unsigned char  cUnused          : 7;
  }  cCtrlStruct;
} CtrlUnion;
void main (void)  {
    unsigned char  dummy = 0x55;
    CtrlUnion  xdata    bitUnion;
    bitUnion.cCtrlStruct.bEnable = dummy & 0x40;
    return;
It results in :
MOV A,#0x55
ANL A,#0x00
MOV R7,A
MOV DPTR, #0x0000
MOVX A,@DPTR
ANL A,#0xFE
ORL A,R7
MOVX @DPTR, A
I thought that the bit result of bitwise logical AND is 1 if result is not 0, else 0.
It seems that I didn't understand ANSI the same way than Keil compiler ? Am I wrong ?
Arnaud DELEULE
  • Jon, thank you for your comments. My [rant] was just to get something off my chest – I didn't really expect a reply. I guessed that the reasons for sfr and sbit were historical and I don't seriously expect Keil to go making huge changes and certainly not any that would affect existing applications.
    I am still left with a couple of gripes that I feel are legitimate and should be considered by Keil. I believe that these suggestions could be implemented without adversely affecting existing applications.
    1-bit fields in structures are very common is my applications and I would think that would go for most other C51 applications too. Whatever failings the 80C51 may have, it is actually quite good at bit-twiddling and that can be a reason for choosing to use a processor from the family. Keil C51, however, does not seem to generate efficient code for 1-bit fields; C51 seems to generate much the same sort of code regardless of the number of the bits in a field. It would be a big help if the compiler/optimiser could treat 1-bit fields as a special case and use bit addressing instructions to accesses a copy of a variable held in, say, the Acc or B register. This would result in faster and more compact code. Also, it would encourage programmers to use bit fields rather than masks – the former being clearer and less error-prone.
    bit defines a memory type, but C51 does not allow a type to be specified for a variable stored in bit memory. Of course, this does not actually stop me writing the software that I want, but if I move a Boolean variable between bit memory and any other memory type I have to add or remove a type definition. Variables that do not have a type make me feel uncomfortable – if I can assign a type to a 1-bit field, why can't I assign a type to a bit? If enumerated types with exactly two possible states could, optionally, be assigned to bit variables, then I could check for breaches of strong typing rules – and that is a software quality issue for me.
    Finally, a compiler option could allow C51 automatically to assign enumerated types (with exactly two possible states) to bit memory when the memory model is small. This would make it quicker and easier to write small applications without having to worry about different types of memory model – an important consideration for Keil beginners. The resulting applications would be faster, more compact and more portable.
    If you are still reading, thanks for your attention. I realise that all this is a lot easier to write about than to actually do! Keil C51 is an excellent compiler – I just love it so much that I want it to be perfect!
  • I don't understand why a 1-bit variable will get a different result depending on its location mapping.
    It's not a question of code size but only of result !
    If you write
    bit  bitValue;
    void main (void)  {
        bitValue = dummy & 0x74;
        return;
    The compiler will generate :
    MOV A, dummy
    ANL A,#0x74
    ADD A, #0xFF
    MOV bitValue, C
    So the bitValue will contain 1, which is the expected result
    If you use a bit-field structure, like in the following code :
    typedef struct  {
    } BitFieldStruct;
    BitFieldStruct  bdata bitUnion;
    void main (void)  {
        bitUnion.bEnable = dummy & 0x74;
        return;
    The generated code is :
    MOV A, dummy
    ANL A,#0x00
    MOV R7, A
    MOV A, bitUnion
    ANL A,#0xFE
    ORL A, R7
    MOV bitUnion, A
    And the stored result will ever be 0 !!!
    This inconsistency of the result is a big problem for me !
    Thanks for all the reply which give me workaround.
    But I think that I compare apple with apple because a 1-bit variable and a 1-bit in a bitfield varaible are quite equivalent in term of size.
    Cheers.
    Arnaud
  • I guess, it can be understood like this:
    bit and unsigned char:1 are DIFFERENT types:
    bit can be seen similar to the bool type in C++: 0 is false, anything else is true.
    Integers of 1 bit size are not boolean. Rather do they still remain integers restricted to the range {0,1}. They are "arithmetical", bits on the other hand are "logical".
    A numerical value casted to bit therefore must yield 1 (i.e. true) if it would succeed as a proposition in a control statement, otherwise it must yield 0 (i.e. false).
    A numerical value casted to an integer with less size (e.g 1) however must be stripped off the "excessive" bits in its binary representation, leaving possibly only the LSB. So these propositions hold:
    (bit)2 == 1;      /*logical use */
    (uchar:1)2 == 0; /* arithmetic use (this isn't C-Syntax, I know)*/
    This explains the difference, but to me too this is an improper mix of types and memory locations, because if bit (if seen as synonym for bool) is a type it should be allowed to reside anywhere.
    This:
    bit xdata externalBit;  /*why not?*/
    should be allowed.
    Norbert
  • Arnaud, the compiler is generating correct code. You are casting from an 8-bit unsigned char to a 1-bit unsigned char. The rule when casting from a large unsigned type to a smaller unsigned type of variable is simply to discard the most significant bits. You will find that the same sort of thing happens when you cast from an unsigned int to an unsigned char – the 8 most significant bits of the unsigned int are discarded.
    Norbert is quite correct to say that bit memory and and a 1-bit bit field are not the same thing. In C you have to be vary careful with Booleans – only logical operators and some functions return truly Boolean results.
    However:
    cannot be allowed because bit is a memory type not a variable type. In fact, C51 does not allow variable stored in bit memory to have a type!
    So, when you compile this:
    typedef struct  {
    } BitFieldStruct;
    void main (void)  {
        return;
    You get this:
    0000 900000      R     MOV     DPTR,#dummy
    0003 E0                MOVX    A,@DPTR
    0004 5400              ANL     A,#00H
    0006 FF                MOV     R7,A
    0007 E500        R     MOV     A,bitUnion
    0009 54FE              ANL     A,#0FEH
    000B 4F                ORL     A,R7
    000C F500        R     MOV     bitUnion,A
    000E         ?C0085:
    000E 22                RET
    So, why is A anded with #00H and not 74H – that will be the compiler predicting that you are not interested in the 7 most significant bits. Note the effect of a small change to your code:
    void main (void)  {
        bitUnion.bEnable = dummy & 0x71;
        return;
    Will give you this:
    0004 5401              ANL     A,#01H
    0006 FF                MOV     R7,A
    000B 4F                ORL     A,R7
    000E         ?C0085:
    000E 22                RET
    That is, bitUnion.bEnable is assigned the value of the least significant bit of dummy.
    If that is not what you wanted, it is because you are not coding correctly. What you actually want is something like this:
    typedef struct  {
        boolean          bEnable          : 1;
    } BitFieldStruct;
    void main (void)  {
        bitUnion.bEnable = ( dummy & 0x74 ) != 0;
        return;
    Which generates this:
    0004 5474              ANL     A,#074H
    0006 6004              JZ      ?C0085
    0008 7F01              MOV     R7,#01H
    000A 8002              SJMP    ?C0086
    000C         ?C0085:
    000C 7F00              MOV     R7,#00H
    000E         ?C0086:
    000E EF                MOV     A,R7
    000F 5401              ANL     A,#01H
    0011 FF                MOV     R7,A
    0012 E500        R     MOV     A,bitUnion
    0014 54FE              ANL     A,#0FEH
    0016 4F                ORL     A,R7
    0017 F500        R     MOV     bitUnion,A
    0019         ?C0087:
    0019 22                RET
    Which is the compiler's rather long-winded way of doing this:
    0006 6004              ADD	A,#FFH
    0014 54FE              MOV	Acc.0,C
    0019         ?C0087:
    0019 22
  • Graham,
    Those are all good ideas. Bit variables, are unfortunately, and oddity of the 8051 (and C16x) architecture. They are only included in the compiler because SETB and CLR instructions are faster than the read-modify-write equivalents.
    As for using the CLR and SETB instructions on bitfields, I'm not sure that this would actually improve the performance. If you consider that the unsigned char/int of the bitfield must be read and written back, that is 2 instructions. A set (LOGICAL OR) operation only requires 1 instruction to set up to 8 bits in a byte. And that would be faster than using several SETB instructions. For the case of setting a single bit, the code generated would be the same.
    A clear operation (LOGICAL AND) is the same--only one instruction is required to clear 1-8 bits.
    A clear and set operation (LOGICAL AND plus LOGICAL OR) requires 2 instructions, the AND mask and the OR mask--but only for multi-bit bitfields.
    Anyway, we'll keep looking at this to see if we can improve code generation for these types of operations.
    As for the bit typing, you can use the BDATA memory space to place typed variables in the bit-addressable area. But I'm not sure this is what you want.
    Jon
  • OK, I understand the thought process
    but I guess that very few people do 1-bit arithmetic.
    But that the way Keil choose and it is one solution.
    Not the way for me, but that's the life ! ;-)
    Thanks all for your help and explanations
    Arnaud
  • Jon, thanks for your comments.
    My apologies to Arnaud for high jacking his thread.
    At the risk of becoming tedious, I decided to do some experiments which have concluded with the following item of test code.
    The experiment has convinced me that bit fields are not accessed efficiently.
    I have been able to go and look at our latest application, it is about 60K bytes long and contains a number of modules doing a wide variety of things and written by a number of different programmers. I searched for the simple case of testing a 1-bit bit field in a simple if statement, I found just under 500 instances. An average saving of just 3 instructions in each case would give a code reduction of 2.5% which I think is significant.
    There are in the 60K application, at least as many logical operations as arithmetic operations – quite possibly more. Many of them involve 1-bit bit fields. Many things in the same application are achieved by means of masks whereas using bit fields would be more elegant, but currently will generate slower code.
    typedef enum { FALSE, TRUE } boolean;
    typedef struct
    	boolean		bit0	: 1;
    	boolean		bit1	: 1;
    	boolean		bit2	: 1;
    	boolean		bit3	: 1;
    	boolean		bit4	: 1;
    	boolean		bit5	: 1;
    	boolean		bit6	: 1;
    	boolean		bit7	: 1;
    } bit_field_type;
    extern bit do_stuff();
    main( void )
    	bit 	/*boolean*/ 	r, s, t;
    	data	boolean			x;
    	bit_field_type 			byte;
    	r = s | t;
    	r = s || t;
    	byte.bit0 = TRUE;
    	byte.bit1 = r;
    	s = byte.bit2;
    	byte.bit2 = s | !t;
    	byte.bit7 = byte.bit5 && byte.bit6;
    	if( byte.bit3 )
    		r = TRUE;
    This:
    	r = s | t;
    Gave me this
                                               ; SOURCE LINE # 25
    0000 A200        R     MOV     C,t
    0002 7200        R     ORL     C,s
    0004 9200        R     MOV     r,C
    But this:
    	r = s || t;
    Gave me this:
    0006 200003      R     JB      s,?C0003
    0009 300003      R     JNB     t,?C0001
    000C         ?C0003:
    000C D3                SETB    C
    000D 8001              SJMP    ?C0002
    000F         ?C0001:
    000F C3                CLR     C
    0010         ?C0002:
    0010 9200        R     MOV     r,C
    I was surprised because I expected that the logical operator would not only be the correct choice when a logical result was required, but also the most efficient. I always use the logical operator in my code where it is appropriate – so there is an opportunity for more compact code here.
    This:
    	byte.bit0 = TRUE;
    Gave me this:
                                               ; SOURCE LINE # 28
    0012 E500        R     MOV     A,byte
    0014 4401              ORL     A,#01H
    0016 F500        R     MOV     byte,A
    That is a read-modify-write. Where the bit field is in data memory this could be reduced to ORL byte,#01H.
    This:
    	byte.bit1 = r;
    Gave me this:
                                              ; SOURCE LINE # 29
    0018 A200        R     MOV     C,r
    001A E4                CLR     A
    001B 33                RLC     A
    001C 5401              ANL     A,#01H
    001E FF                MOV     R7,A
    001F 25E0              ADD     A,ACC
    0021 FF                MOV     R7,A
    0022 E500        R     MOV     A,byte
    0024 54FD              ANL     A,#0FDH
    0026 4F                ORL     A,R7
    0027 F500        R     MOV     byte,A
    But the same could have been done with less than half as much code:
    0018 A200        R     MOV     C,r
    001A E500        R     MOV     A,byte
    001C 54FD              MOV     Acc.1,C
    001E F500        R     MOV     byte,A
    This:
    	if( byte.bit3 )
    Gave me this:
                                               ; SOURCE LINE # 36
    006F FF                MOV     R7,A
    0070 13                RRC     A
    0071 13                RRC     A
    0072 13                RRC     A
    0073 541F              ANL     A,#01FH
    0075 30E002            JNB     ACC.0,?C0007
    But all that is needed is something like this:
    006F E500        R     MOV     A,byte
    0071 30E002            JNB     ACC.3,?C0007
