I had the demo version of uVision 2, but did not filnd the C51PFS.LIB file in the LIB Directory. Is it shipped with comlete package or i can get it from http://www.keil.com ? Please advice. Thanks.
No, and you cant have C51FPS.LIB either
Hi, I have a full version of uv2 v7.20 and am lacking this file. ? I have c51bfps.lib but only the 'b' versions. The linker won't read this file, and still wants the c51fps.lib file anyway. what gives? please advise? errors messages below: *** ERROR L103: EXTERNAL ATTRIBUT DO NOT MATCH PUBLIC SYMBOL: ?_PRINTF?BYTE MODULE: C:\Keil\C51\LIB\C51BFPL.LIB (PRINTF) *** FATAL ERROR L210: I/O ERROR ON INPUT FILE: EXCEPTION 0021H: PATH OR FILE NOT FOUND FILE: C:\KEIL\C51\LIB\C51FPS.LIB
Hi, I have a full version of uv2 v7.20 and am lacking this file. Please contact technical support. They can help you with the problem. Jon
thanks... yes. I read the older messages on this thread. I am NOT using an eval license. However, things are working now. I reinstalled a newer version and things look good now. My old install might have been a mess.
