Combining C and assembly codes
Would appreciate if someone can tell/show me how to combine C and assembly code in the Uvision 2?
  • "How will acess a code in assembly language through a simple progrse in C language?"
    Sorry, don't understand your question.
    I think this has all been thoroughly covered in the Manuals and previous discussions?
    If not, then precisely which point is confusing you?
  • Hi Mark/Andrew,
    Read through your advice to others. Splendid! Maybe either of you can assist me too.
    I came across this forum when I am seeking for some quick guide of sharing code of different files of C and .a51.
    Calling each other from C to get the function written in .a51 or vice-versa is completed. Went through c2asm2c.zip and it worked perfectly. However, I encounter some trouble when I need to pass on some variables that need to be manipulated from .a51 to .c
    My case:-
    Main code is in .a51. Requires to call a function that adds 20 slightly different 8bit data bytes and then take its average (i.e. by division).
    Writing the function above in .a51 is a pain due to unavailable 16bit-addition in 8051 done under Keil uV2.
    My solution thought:- is to write the addition function in C so addition can be done much more easily.
    Problem:- how do I pass the variables/registers defined in .a51 to the C function to be called from .a51 environment? The C function failed to recognize the similar declared register under .a51 before. Do I need to declare them under a new name OR use the similar name of data registers OR can use some global declaration of data registers. But how?
    Appreciate some really cool advice if available.
    Cheers,
    James
