Mgd 4.9.0
Device: Huawei Mate10
Android: 8.0
In Device Manager, I have installed MGD Android App and Root Interceptor,
after device reboot, Device Manager always tell that Root Interceptor " Needs update", If i click the update button,
it will install the components success and reboot, but again "Needs update", whatever how much times I followed the update button.
And I can't get any trace data.
And I found the libGLES_mgd.so is installed to the /vendor/lib/egl and /vendor/lib64/egl directory.
Don't known how to solve this problem.
same problem, how to solve this?
Hello,We have had reports of symbolic links not working on Huawei Mate 10.You can try deleting the libGLES.so and libGLES files (which are symbolic links), then doing a hard copy of the MGD interceptor library (libGLES_mgd.so).e.g.rm /system/lib/egl/libGLES.sorm /system/lib/egl/libGLEScp /system/lib/egl/libGLES_mgd.so /system/lib/egl/libGLES.socp /system/lib/egl/libGLES_mgd.so /system/lib/egl/libGLESThe User Guide section "Target Installation -> Android -> Rooted Android" explains where MGD is installed. You will need to update all of the interceptor library locations.If that doesn't work, could you try to trace a device, and share with me the logcat output?
Kind regards,Liam
