is extension GL_OES_EGL_image_external_essl3 not working properly in compute shader on Mali G71 gpu?
I am trying to do some image processing on the camera feed using the compute shader on Android devices. However I am reading all black from the samplerExternalOES on the Samsung S8.
I bind the texture like so:
GLES31.glActiveTexture(GLES31.GL_TEXTURE0);
GLES31.glBindTexture(GLES11Ext.GL_TEXTURE_EXTERNAL_OES, mTextures[0]);
GLES31.glUniform1i(mCameraUniform[TEXTURE], 0);
My compute shader:
"#version 310 es\n"
+"#extension GL_OES_EGL_image_external_essl3 : enable\n"
+"uniform samplerExternalOES sTexture;\n"
+"uniform float width; \n"
+"uniform float height; \n"
+"layout (local_size_x = 4, local_size_y = 4, local_size_z = 1) in;\n"
+"void main()\n"
+"{\n"
+ " ivec2 storePos = ivec2(gl_GlobalInvocationID.xy);\n"
+ " vec4 cameraColor = texture(sTexture, vec2(float(gl_GlobalInvocationID.x)/width,float(gl_GlobalInvocationID.y)/height)).rgba;\n"
The code compiles and runs without throwing any errors, the shaders are computing. However the camera texture is returning all black (0, 0, 0, 1).
The code is working as intended on Adreno GPUs.
Is samplerExternalEOS not supported in compute shaders or am I doing it wrong?
  • Hi Denis,
    The issue has been fixed in our released drivers for ~8 months, but whether a device gets an update is controlled by the device manufacturer and not under our control.
    For Midgard devices (Mali-Txxx) you need driver release r23p0 or higher.
    For Bifrost devices (Mali-Gxx) you need driver release r10p0 or higher.
    Cheers,
    Pete
