This is a list of Vulkan driver issues which are known to cause problems, have been fixed in the latest driver, but might not have gotten into updated drivers yet.
VK_REMAINING_* enums
image_memory_barrier.subresourceRange.levelCount = VK_REMAINING_MIP_LEVELS; image_memory_barrier.subresourceRange.layerCount = VK_REMAINING_ARRAY_LAYERS;
In some cases, this will directly crash the driver in vkCmdPipelineBarrier on older drivers. You can probably guess what the bug is :) Workaround is simply using the "correct" numbers for MIP_LEVELS and ARRAY_LAYERS instead.
Sampler parameters passed to functions
If you have code like:
vec4 function(sampler2D sampler, vec2 uv) { return texture(sampler, uv); }
This will cause problems on older drivers such as R12 (Midgard) when using a glslang version from last year or so. The workaround would be inlining with spirv-opt or avoiding this kind of code.
textureQueryLod
This crashes on R12 (Midgard), avoid altogether on this driver. However, it should be noted that textureQueryLod does not exist in GLES, only Vulkan (through desktop GLSL), so finding a workaround might not be difficult.
SPIRV-opt common uniform elimination pass
Avoid SPIR-V codegen where you end up loading an entire UBO with OpLoad, which this optimization typically ends up doing.
Partially loading depth/stencil
On older drivers, if you try to LOAD_OP_CLEAR depth, but LOAD_OP_LOAD stencil, this might lead to issues where loading and clearing does not work properly. On older drivers, use the same load operations for depth and stencil if you have a packed depth/stencil attachment. Easiest workaround is to just load DEPTH as well if you need this kind of render pass (although LOAD_OP_LOAD is discouraged on tile-based architectures).
Blending on B10G11R11
Older drivers did not report that B10G11R11_UFLOAT could blend with VK_FORMAT_FEATURE_COLOR_ATTACHMENT_BLEND_BIT, but this works fine. As a workaround, you can assume that blending on this format just works.
Pipeline cache header version
On older drivers, the header in vkGetPipelineCacheData did not return VK_PIPELINE_CACHE_HEADER_VERSION_ONE properly in the blob header. You can just assume it's correct as a workaround.
MSAA on-tile resolve and MRT on swapchain images renders corrupt image
This bug affects very specifically Galaxy S7 on Android N with apiVersion 1.0.11 for the physical device. The workaround is to not use these features directly on the swapchain for this device + android version + driver version. To my knowledge, drivers have been updated on this device, but you may run into it on older images.
Primitive restart with vertexOffset/indirect and 16-bit indices renders corrupt image
On drivers before R22 (Midgard) / R10 (Bifrost), using primitive restart (16-bit indices) can render incorrectly if vertexOffset is non-zero in vkCmdDrawIndexed. A workaround for this is using vertexOffset = 0 and binding vertex buffers at the appropriate offset. Similar issue happens if you use indirect indexed draws (which might need vertex offset).
Viewports do not clip at clip-space boundaries
On drivers before R15 (Midgard), using a viewport which is a subset of the frame will not perform viewport bounds clipping properly when rendering outside the viewport area. The clipping behavior is purely guided by scissor tests on these drivers, so a simple workaround is to simply clip the scissor box against the viewport.
Renderpasses which only CLEAR and do not have any draw calls can lead to corrupt rendering
On drivers before R14 (Bifrost) and R26 (Midgard), using empty render passes which only clear color, but does not render anything can lead to corrupt rendering later. Transactional elimination state will not be updated properly, so what can happen is that you render something, but it is wrongly discarded, leading to odd tile-like artifacts.
To workaround this, you can check in EndRenderPass if any draw calls were submitted, and if not, emit a dummy draw call which renders outside the screen.
The best workaround is to defer the clear until you need to render anything if possible, as just clearing is not very bandwidth efficient.
Great initiative!
Found one more - passing VkViewport.minDepth > VkViewport.maxDepth to vkCmdSetViewport appears to misbehave on older drivers but not newer ones.
It's specified that this case should work, producing the expected reverse depth output. See https://github.com/KhronosGroup/Vulkan-LoaderAndValidationLayers/issues/2224 for a bit of discussion.
I'll try to get some confirmation that this has been a bug in the past.
By the way, for each of these issues, it would be nice to have the version number from which it is expected to work. That way, we can safely disable workarounds on newer drivers, which would be useful in some cases.
I have indirectly confirmed through user reports that reverse depth is an issue in driver 428.811.2674 but is fixed in 482.381.3347 (0x7897dd13), if that helps. So there was a fix and it was somewhere in between.
Another one that should probably be mentioned here: Primitive Restart functionality (pass index 0xFFFF to break up triangle strips) is not working on Mali, at least not with 16-bit indices, and thus Dolphin had to disable the use of it: github.com/.../6435
Workaround is simple, just use indexed triangle lists instead.
That sounds bizarre, need to verify that.
EDIT: Reproduced.
Looks like dynamic viewports don't work on Mali-T880 (Vendor 13b5 Device 8802000 Driver 212.387.1927). We're using dynamic viewports for shadowmaps rendering. Could you please confirm? Are there any workarounds?
I don't know of any such bug. Do you have a repro case?
I've used dynamic viewports since the very beginning, and I haven't hit any bug with this.
for us setting viewport smaller than render target and drawing something larger than render target result in whole render target been filled. one thing i didn't check though is setting scissor with viewport. right now scissor is static and don't change with viewport. will try this today
Hm, good point. I now recall a very old bug (like, 2+ years) where viewports would not perform clipping, and you'll need scissor as well to make sure it clips at the viewport boundary. The driver hash doesn't tell me much, how old is that driver?
the device is s7 and i believe it has stock android (7.0)
What is the GLES version?
how do i check that? i'm not super experienced with androids. so scissor apparently fixes the incorrect clipping but still shadowmap rendering is broken. could it be related to d16_unorm depth format or maybe depth only rendering?
disregard previous message. i forgot to disable some of the debug code. scissor did the trick!
