Can Mali G71 GPU be tested on Huawei P10 android mobile?
I am trying to test my android app which has OpenCL native code. I have Huawei P10 which has Android Nougat. It has Cortex A53 & Cortex A73 CPUs and Mali G71 bifrost GPU. I could not link libOpenCL.so at runtime as its always showing linker failure error ""/system/vendor/lib64/egl/libGLES_mali.so" ("/vendor/lib64/egl/libGLES_mali.so") needed or dlopened by libOpenCL.so" is not accessible for the namespace [name="classloader-namespace]". if either libOpenCL.so or libGLES_mali.so  is a private library, Is there any other OpenCL library that can be used to run OpenCL on Mali G71. I'm using ARM Compute OpenCL library at compile time. During runtime, its searching in system path. As a result, I'm getting access issue. Has anyone encountered this issue?
