I'm experiencing quite slow OpenGL ES performance with a Mali-T760 MP4 600MHz (RK3288 chip, Orbbec Persee product) with Ubuntu linux compared to Android.
The triangle sample from the Mali OpenGL ES SDK draws one triangle on screen in 1920x1080 with 15fps.
The output of glxinfo:
glxinfo
name of display: :0.0 display: :0 screen: 0 direct rendering: Yes server glx vendor string: SGI server glx version string: 1.4 server glx extensions: GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer, GLX_OML_swap_method, GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGI_make_current_read client glx vendor string: Mesa Project and SGI client glx version string: 1.4 client glx extensions: GLX_ARB_create_context, GLX_ARB_create_context_profile, GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float, GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_create_context_es2_profile, GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer, GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer, GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control, GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group, GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync GLX version: 1.4 GLX extensions: GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer, GLX_MESA_multithread_makecurrent, GLX_OML_swap_method, GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGI_make_current_read OpenGL vendor string: Mesa Project OpenGL renderer string: Software Rasterizer OpenGL version string: 2.1 Mesa 10.1.3 OpenGL shading language version string: 1.20 OpenGL extensions: GL_3DFX_texture_compression_FXT1, GL_AMD_shader_trinary_minmax, GL_ANGLE_texture_compression_dxt3, GL_ANGLE_texture_compression_dxt5, GL_APPLE_object_purgeable, GL_APPLE_packed_pixels, GL_APPLE_vertex_array_object, GL_ARB_clear_buffer_object, GL_ARB_copy_buffer, GL_ARB_debug_output, GL_ARB_depth_clamp, GL_ARB_depth_texture, GL_ARB_draw_buffers, GL_ARB_draw_elements_base_vertex, GL_ARB_draw_instanced, GL_ARB_explicit_attrib_location, GL_ARB_fragment_coord_conventions, GL_ARB_fragment_program, GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader, GL_ARB_framebuffer_object, GL_ARB_get_program_binary, GL_ARB_half_float_pixel, GL_ARB_half_float_vertex, GL_ARB_invalidate_subdata, GL_ARB_map_buffer_alignment, GL_ARB_map_buffer_range, GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query, GL_ARB_occlusion_query2, GL_ARB_pixel_buffer_object, GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_provoking_vertex, GL_ARB_robustness, GL_ARB_sampler_objects, GL_ARB_shader_objects, GL_ARB_shading_language_100, GL_ARB_shadow, GL_ARB_sync, GL_ARB_texture_border_clamp, GL_ARB_texture_compression, GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map, GL_ARB_texture_env_add, GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3, GL_ARB_texture_float, GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_mirrored_repeat, GL_ARB_texture_non_power_of_two, GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_storage, GL_ARB_texture_swizzle, GL_ARB_transpose_matrix, GL_ARB_vertex_array_bgra, GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_binding, GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader, GL_ARB_window_pos, GL_ATI_blend_equation_separate, GL_ATI_draw_buffers, GL_ATI_envmap_bumpmap, GL_ATI_fragment_shader, GL_ATI_separate_stencil, GL_ATI_texture_compression_3dc, GL_ATI_texture_env_combine3, GL_ATI_texture_float, GL_ATI_texture_mirror_once, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array, GL_EXT_copy_texture, GL_EXT_depth_bounds_test, GL_EXT_draw_buffers2, GL_EXT_draw_instanced, GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_blit, GL_EXT_framebuffer_object, GL_EXT_gpu_program_parameters, GL_EXT_multi_draw_arrays, GL_EXT_packed_depth_stencil, GL_EXT_packed_pixels, GL_EXT_pixel_buffer_object, GL_EXT_point_parameters, GL_EXT_polygon_offset, GL_EXT_provoking_vertex, GL_EXT_rescale_normal, GL_EXT_secondary_color, GL_EXT_separate_shader_objects, GL_EXT_separate_specular_color, GL_EXT_shadow_funcs, GL_EXT_stencil_two_side, GL_EXT_stencil_wrap, GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_array, GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_latc, GL_EXT_texture_compression_rgtc, GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map, GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add, GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp, GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_texture_sRGB, GL_EXT_texture_sRGB_decode, GL_EXT_texture_shared_exponent, GL_EXT_texture_swizzle, GL_EXT_vertex_array, GL_EXT_vertex_array_bgra, GL_IBM_multimode_draw_arrays, GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate, GL_KHR_debug, GL_MESA_pack_invert, GL_MESA_window_pos, GL_MESA_ycbcr_texture, GL_NV_blend_square, GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_fragment_program_option, GL_NV_light_max_exponent, GL_NV_packed_depth_stencil, GL_NV_point_sprite, GL_NV_texgen_reflection, GL_NV_texture_env_combine4, GL_NV_texture_rectangle, GL_OES_read_format, GL_S3_s3tc, GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays 64 GLX Visuals visual x bf lv rg d st colorbuffer sr ax dp st accumbuffer ms cav id dep cl sp sz l ci b ro r g b a F gb bf th cl r g b a ns b eat ---------------------------------------------------------------------------- 0x0a2 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None 0x0a3 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x0a4 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None 0x0a5 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x0a6 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 8 0 0 0 0 0 0 None 0x0a7 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 8 16 16 16 0 0 0 Slow 0x0a8 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 8 0 0 0 0 0 0 None 0x0a9 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 8 16 16 16 0 0 0 Slow 0x0aa 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None 0x0ab 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x0ac 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None 0x0ad 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x0ae 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None 0x0af 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x0b0 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None 0x0b1 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x0b2 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x0b3 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x0b4 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x0b5 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x0b6 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 None 0x0b7 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 8 16 16 16 16 0 0 Slow 0x0b8 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 None 0x0b9 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 8 16 16 16 16 0 0 Slow 0x0ba 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None 0x0bb 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow 0x0bc 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None 0x0bd 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow 0x0be 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x0bf 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x0c0 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x0c1 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None 0x0c2 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x0c3 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None 0x0c4 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x0c5 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 8 0 0 0 0 0 0 None 0x0c6 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 8 16 16 16 0 0 0 Slow 0x0c7 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 8 0 0 0 0 0 0 None 0x0c8 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 8 16 16 16 0 0 0 Slow 0x0c9 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None 0x0ca 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x0cb 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None 0x0cc 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x0cd 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None 0x0ce 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x0cf 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None 0x0d0 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x0d1 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x0d2 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x0d3 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x0d4 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x0d5 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 None 0x0d6 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 8 16 16 16 16 0 0 Slow 0x0d7 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 None 0x0d8 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 8 16 16 16 16 0 0 Slow 0x0d9 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None 0x0da 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow 0x0db 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None 0x0dc 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow 0x0dd 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x0de 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x0df 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x0e0 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x041 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 96 GLXFBConfigs: visual x bf lv rg d st colorbuffer sr ax dp st accumbuffer ms cav id dep cl sp sz l ci b ro r g b a F gb bf th cl r g b a ns b eat ---------------------------------------------------------------------------- 0x042 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None 0x043 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x044 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None 0x045 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x046 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 8 0 0 0 0 0 0 None 0x047 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 8 16 16 16 0 0 0 Slow 0x048 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 8 0 0 0 0 0 0 None 0x049 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 8 16 16 16 0 0 0 Slow 0x04a 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None 0x04b 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow 0x04c 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None 0x04d 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow 0x04e 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 8 0 0 0 0 0 0 None 0x04f 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 8 16 16 16 0 0 0 Slow 0x050 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 8 0 0 0 0 0 0 None 0x051 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 8 16 16 16 0 0 0 Slow 0x052 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None 0x053 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x054 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None 0x055 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x056 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 8 0 0 0 0 0 0 None 0x057 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 8 16 16 16 0 0 0 Slow 0x058 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 8 0 0 0 0 0 0 None 0x059 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 8 16 16 16 0 0 0 Slow 0x05a 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None 0x05b 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x05c 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None 0x05d 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x05e 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None 0x05f 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x060 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None 0x061 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x062 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x063 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x064 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x065 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x066 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 None 0x067 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 8 16 16 16 16 0 0 Slow 0x068 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 None 0x069 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 8 16 16 16 16 0 0 Slow 0x06a 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None 0x06b 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow 0x06c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None 0x06d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow 0x06e 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x06f 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x070 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x071 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x072 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None 0x073 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x074 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None 0x075 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x076 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 8 0 0 0 0 0 0 None 0x077 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 8 16 16 16 0 0 0 Slow 0x078 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 8 0 0 0 0 0 0 None 0x079 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 8 16 16 16 0 0 0 Slow 0x07a 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None 0x07b 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow 0x07c 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None 0x07d 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow 0x07e 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 8 0 0 0 0 0 0 None 0x07f 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 8 16 16 16 0 0 0 Slow 0x080 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 8 0 0 0 0 0 0 None 0x081 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 8 16 16 16 0 0 0 Slow 0x082 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None 0x083 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x084 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None 0x085 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x086 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 8 0 0 0 0 0 0 None 0x087 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 8 16 16 16 0 0 0 Slow 0x088 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 8 0 0 0 0 0 0 None 0x089 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 8 16 16 16 0 0 0 Slow 0x08a 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None 0x08b 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x08c 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None 0x08d 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x08e 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None 0x08f 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x090 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None 0x091 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x092 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x093 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x094 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x095 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x096 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 None 0x097 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 8 16 16 16 16 0 0 Slow 0x098 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 None 0x099 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 8 16 16 16 16 0 0 Slow 0x09a 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None 0x09b 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow 0x09c 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None 0x09d 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow 0x09e 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x09f 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x0a0 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x0a1 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
Tried with Ubuntu 14.04 drivers provided by Orbbec, and the firefly/malit76xr5p006rel0linux1fbdevtar.gz driver from https://developer.arm.com/products/software/mali-drivers/user-space with similar results.
Is this expected? Or can I do something to increase the performance in Linux?
Any help would be appreciated,
-Gabor
Hi Gabor,
Can you please try with the latest drivers?
developer.arm.com/.../malit76xr12p004rel0linux1fbdevtar.gz
Also, the glxinfo seems to say the board it's using the Mesa software rasterizer instead of our driver. Can you be sure the board is using the Mali driver and run glxinfo again?
Regards,
Daniele
Hi Daniele,
Thank you. I didn't try the latest driver because it is armsf and the Orbbec Persee is armhf. So I chose the latest armhf version I could find.
Sorry about the wrong `glxinfo` output. I will make sure to test it with the Mali driver.
Best,
Gabor
