Help eglSwapBuffers() procedure in triple buffering
Dear All,
I confused about eglSwapBuffers() function on ARM MALI400
First, Here is development environment.
Target Chip: A53+Mali400MP2 chip
Target Board OS: Linux OS 32 Bit
Mali Drivers: r6p1-01rel0
Target Application: OpenGLES2.0,  fbdev based Triple Buffering
Host OS: Fedora fc20.x86_64bit
Here is my main rendering loop.
The loop receives renderFrameEvent messages sent from another thread that contain a list of OpenGL commands to execute.
All of the OpenGL drawing calls are executed in the renderFrameEvent->commandList->flush() call.
while ((message = thread->msgPort.waitPort())) {
        printf("Message Loop message=%s,pending=%d\n", message->getClass().c_str(), thread->msgPort.countPending());
        if (message->getClass() == "RenderOpenGLFrameEvent") {
            std::chrono::time_point<std::chrono::high_resolution_clock> startTime, renderTime, endTime;
// Start Timing
            startTime = std::chrono::high_resolution_clock::now();
           renderFrameEvent = std::static_pointer_cast<RenderOpenGLFrameEvent> (message);
// Draw
            renderFrameEvent->commandList->flush();
            eglSwapBuffers(egl_display, egl_surface);
// End Timing
            renderTime = std::chrono::high_resolution_clock::now();
            std::chrono::duration<double> renderDuration = renderTime - startTime;
            printf("renderDuration=%f\n",renderDuration.count());
This is the output when you press a button to scroll:
Message Loop message=RenderOpenGLFrameEvent,pending=0
renderDuration=0.000656
renderDuration=0.000631
renderDuration=0.000601
renderDuration=0.000619
renderDuration=0.009073
Message Loop message=RenderOpenGLFrameEvent,pending=1
renderDuration=0.016451
Message Loop message=RenderOpenGLFrameEvent,pending=2
renderDuration=0.016368
renderDuration=0.016457
So there are no frames pending at the start of this log, so two back buffers should be available. eglSwapBuffers() is then called 6 times.
With triple buffering, eglSwapBuffers() should probably not wait for the vertical sync for the first two frames, otherwise it can't pipeline the operation.
I don't know why 4 frames return immediately in this case though, what do I need to do to accurately measure the frame rate?
Thanks!
  • > hat do I need to do to accurately measure the frame rate?
    In general for most embedded systems you need to leave it for a few 100 ms to get into a steady state anyway; if the device has been mostly idle it will take a while for things like DVFS to ramp up the clock frequencies, so in general I would suggest running a test of at least 5 seconds, discarding the first 2.
    In terms of measuring GPU time, the standard approaches are:
    • Disable vsync during development
    • Use a GPU profiler such as DS-5 Streamline to measure GPU activity directly (the community edition is available free of charge)
    • Render the application to an offscreen FBO 100 times for every on-screen frame.
    HTH,
    Pete
