[r7p0 Driver] Does Midgard(3rd gen) Mali-T760/720 series support  "Android Extension Pack"?
Hello, my name is SangMin.
Does <Midgard(3rd gen) Mali-T760/720 series> support  "Android Extension Pack"?
I know that <r5p1 driver> supports OpenGL ES3.1.
I wonder if <r7p0 driver> supports  "GL_ANDROID_extension_pack_es31a".
(Tessellation, geometry shader, Shader5)
Thank you!
  • Mali-T760 will support the Android Extension Pack in the r7p0 or r8p0 drivers; Mali-T720 does not support the entire extension pack but does support some of the individual component extensions.
    Kind regards,
    Pete
  • I've recently seen a MediaTek dev board that comes with r7p0 and indeed it supports AEP. Though no features yet implemented like base_vertex and buffer_range/storage. Also r7p0 finally reports it's GL version to a correct place which is nice
  • Yes, try to check Samsung Galaxy S6 or Note 5 devices (Exynos Chipset), r7p0 driver is ready in Android 6.0.1. You can check Mali extensions with Hardware Info application. AEP is there.
