How to share texture memory
i work on firefly/rk3288,and got the same problem as this discussion http://community.arm.com/thread/8116
when i try to use eglCreateImageKHR , it returned EGL_NO_IMAGE_KHR, error code is EGL_BAD_PARAMETER(0x300c),accroding to this site https://www.khronos.org/registry/egl/extensions/KHR/EGL_KHR_image_base.txt, it seem the <target> or <attrib_list> is invalid, but i am
doubt,i use as below
const EGLint img_attribs[] = {
     EGL_IMAGE_PRESERVED_KHR, EGL_TRUE,
     EGL_NONE
EGLImageKHR image = eglCreateImageKHR (display, EGL_NO_CONTEXT, EGL_NATIVE_PIXMAP_KHR,
      &pixmap, img_attribs);
pixmap is define as
#define YUYV_FORMAT  0x001022A88LL
struct fbdev_pixmap
  int width, height;
  struct
  /** @brief The line stride of each plane.
  * For each plane required by the format, the number of bytes from one line of samples to the next. Other entries in
  * the array should be 0.
  khronos_usize_t stride;
  /** @brief The byte size of each plane.
  * For each plane required by the format, the number of bytes taken up by that plane. That includes any space wasted
  * in partially-used blocks.
  khronos_usize_t size;
  /** @brief The offset from the memory handle to each plane.
  * For each plane required by the format, the number of bytes from the start of the allocation to the start of that
  * plane. Other entries in the array should be 0.
  khronos_usize_t offset;
  planes[3];
  /** An integer that specifies the format of the pixmap. Its meaning is known by the Mali driver. */
  uint64_t pixmap_format;
  /* dma_buf fd for each of the plan */
  int handles[3];
struct fbdev_pixmap pixmap;
memset(&pixmap, 0, sizeof(struct fbdev_pixmap));
pixmap.width = width;
pixmap.height = height;
pixmap.handles[0] = dma_fd;
pixmap.planes[0].stride = width * pixel_size;
pixmap.planes[0].size = width * height * pixel_size;
pixmap.pixmap_format = YUYV_FORMAT;
so,i dont know where is the problem
my mali lib version is mali-t76x_r5p0-06rel0_linux_1+fbdev
and i need the definition of struct fbdev_pixmap on YUYV_FORMAT and GL_RGBA format, thx
