Cannot find any frames
I captured system and GPU info via Arm_Performance_Studio_2024.3 on ubuntu 20.04 successfully,
while i cannot generate a performance report(Streamline-cli -pa <*.apc>)
Importing capture...
Fetching data...
Preparing report type html...
WARNING: The series "Execution engine cycles" could not be found.
Ensure that you are running a capture made with a matching version of Streamline and that all the expression values in your report configuration are correct.
WARNING: The series "Varying cycles" could not be found.
WARNING: The series "Draw calls" could not be found.
WARNING: The series "Vertices" could not be found.
WARNING: The series "Total primitives" could not be found.
WARNING: The series "Visible primitives" could not be found.
WARNING: The series "External read bytes" could not be found.
WARNING: The series "External write bytes" could not be found.
WARNING: The series "Total external bytes" could not be found.
WARNING: The series "Overdraw" could not be found.
Problems were found preparing html report:
WARNING: Build name not provided. You can add this as a command line argument (use --build-name).
WARNING: Build timestamp not provided. You can add this as a command line argument (use --build-timestamp).
WARNING: Device name not provided. You can add this as a command line argument (use --device-name).
ERROR: Cannot find any frames. Please refer to the user guide for methods of providing frame data to Performance Advisor.
is there something wrong with these tools call, or any solution to solve this problem
0
