Can't confirm adb path in frame adviser gui in mac os.
Fullscreen
1
2
3
4
The device manager failed to initialize: Could not run adb, is the path 'adb' correct?
Adb failed with exit code 2.
Command: version
Output : execve failed: No such file or directory
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
hi i'm not able to select the apply and close button to point out the adb path.
The adb is installed by android studio in a standard path, and i'v added it to system path.
Frame adviser version:
Build date: Dec 1 2023
GUI build: 13b99d11e42c94d22c9321d66feb5c1733767412
Backend build: d1594be6145fe5da06f72754f570eee482255f2c
Macos: 13.6.2 (22G320) M1 Pro
0
