Confuse about Vertex Buffer And VTF affect VertexShader LS
Hello Arm,
Recently I use Malioc to analyze UE4 Niaggara Particle System Related Shader on ES31,  and I have some confuses about how vertex attritubes affect VertexShader LS.
The Vertex Shader which used for Niaggara Particle Sprite have too many texelFetch on VS which cause T Bounded and stack spiling on Mali-G71. The VS code and Malioc Reports is here,
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
#version 310 es
#ifdef GL_EXT_texture_buffer
#extension GL_EXT_texture_buffer : enable
#endif
#define HLSLCC_DX11ClipSpace 1
// end extensions
void compiler_internal_AdjustInputSemantic(inout vec4 TempVariable)
#if HLSLCC_DX11ClipSpace
TempVariable.y = -TempVariable.y;
TempVariable.z = ( TempVariable.z + TempVariable.w ) / 2.0;
#endif
void compiler_internal_AdjustOutputSemantic(inout vec4 Src)
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
Mali Offline Compiler v7.5.0 (Build 30e352)
Copyright 2007-2022 Arm Limited, all rights reserved
Configuration
Hardware: Mali-G71 r0p1
Architecture: Bifrost
Driver: r36p0-00rel0
Shader type: OpenGL ES Vertex
Main shader
Position variant
Work registers: 64
Uniform registers: 128
Stack spilling: 16 bytes
16-bit arithmetic: 0%
So, I make a litte test which I use generic Read Particle Data from Vertex Buffer replacing of VTF.  Modied code and Malioc Report is here,
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
#version 310 es
#endif
// end extensions
#endif
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
Configuration
Main shader
Position variant
Work registers: 50
Stack spilling: false
But VS just has 7 layout in_Attributes and LS seems larger than expected. So I did more test , then I found when I delete the
CalculateHeightFog part code, the LS became better. Position Variant LS also became 7 from 14 which I confuse that CalculateHeightFog is not affect Position Variant.
whiout CalculateHeightFog  VS Code and Malioc Reposrts,
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
#version 310 es
#endif
// end extensions
#endif
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
Main shader
Position variant
Work registers: 47
A LS T Bound
Total instruction cycles: 21.33 7.00 0.00 A
Shortest path cycles: 8.50 7.00 0.00 A
Longest path cycles: 15.93 7.00 0.00 A
So, I just want to ask
1. why calculate heigh fog affect LS even if the Position Variant?
2. "if.. else.." Branching seems like do not affect vertex buffer Loading but can braching TexelFetch(), Is it possible that I can slot some optional data like "custom facing", "custom aligning" using TexBuffer to optimize the shortest path?
0
