I have a very simple shader. Basiclly, it just sample a texture and do a cut off based on the a scalar. All variables are medium percision.
#version 310 es precision mediump float; precision highp int; #define HLSLCC_ENABLE_UNIFORM_BUFFERS 1 #if HLSLCC_ENABLE_UNIFORM_BUFFERS #define UNITY_UNIFORM #else #define UNITY_UNIFORM uniform #endif #define UNITY_SUPPORTS_UNIFORM_LOCATION 1 #if UNITY_SUPPORTS_UNIFORM_LOCATION #define UNITY_LOCATION(x) layout(location = x) #define UNITY_BINDING(x) layout(binding = x, std140) #else #define UNITY_LOCATION(x) #define UNITY_BINDING(x) layout(std140) #endif uniform mediump float _Cutoff; UNITY_LOCATION(0) uniform mediump sampler2D _MainTex; in highp vec2 vs_TEXCOORD0; layout(location = 0) out mediump vec4 SV_Target0; mediump vec4 u_xlat16_0; bool u_xlatb0; mediump float u_xlat16_1; void main() { u_xlat16_0 = texture(_MainTex, vs_TEXCOORD0.xy); u_xlat16_1 = u_xlat16_0.w + (-_Cutoff); SV_Target0 = u_xlat16_0; #ifdef UNITY_ADRENO_ES3 u_xlatb0 = !!(u_xlat16_1<0.0); #else u_xlatb0 = u_xlat16_1<0.0; #endif if(u_xlatb0){discard;} return; }
Why does Mali Offline Complier show 16-bit arithmetic zero?
I find that some operations such as alpha clip, ddx and ddy can decrease 16-bit arithmetic tremendously. Why?
HI TBWorkss, The behaviour you are seeing is mostly a reporting artefact of how we calculate the number of 16-bit operations.
We only count pure arithmetic instructions (interpolation, texturing and blending not included), of which this shader has very few. We also only count instructions that are entirely 16-bit (16-bit input, 16-bit data processing, 16-bit output). The discard instruction only has a 32-bit data path, so will include implicit widening of a 16-bit input. This has no impact on performance, but does mean it doesn't show up in the stats.
HTH, Pete
I see. Some built-in function only have 32-bit data path. Although I provide them with 16-bit params, they still handle them as 32-bit params?
Yes.
