I have an 32-bit Unity application.
I can connect to the Android 9 device using the next command: "python3 lwi_me.py --lwi-mode=capture --32bit".
But when I try to connect to the same application on Android 10 device I got the error:
--lwi-api=vulkan not specified, assuming GLES application. To use Vulkan, specify --lwi-api=vulkan
--32bit specified, assuming 32bit application
Searching for devices:
0cd7d2df9906 / Redmi 7A found
Select a device:
Auto-selected 0cd7d2df9906 / Redmi 7A
Searching for debuggable packages:
1 debuggable package found
Select a debuggable packages:
Auto-selected com.XXXXXXXXXXX
Searching for a Mali GPU:
No Mali GPU found
Configuring LWI
--lwi-gles-layer-lib-path not specified, assuming /Applications/Arm_Mobile_Studio_2021.3/performance_advisor/lwi/helpers/../target/android/arm/32-bit/libGLES_layer_lwi.so
Enabling GLES debug layer...
Traceback (most recent call last):
File "/Applications/Arm_Mobile_Studio_2021.3/performance_advisor/lwi/helpers/lwi_me.py", line 657, in <module>
sys.exit(main())
File "/Applications/Arm_Mobile_Studio_2021.3/performance_advisor/lwi/helpers/lwi_me.py", line 604, in main
enable_gles_debug_layer(device, args, glesLayerLibPath)
File "/Applications/Arm_Mobile_Studio_2021.3/performance_advisor/lwi/helpers/lwi_me.py", line 225, in enable_gles_debug_layer
device.adb("shell", "settings", "put", "global", "enable_gpu_debug_layers", "1")
File "/Applications/Arm_Mobile_Studio_2021.3/performance_advisor/lwi/helpers/gator_me.py", line 265, in adb
rep = sp.run(commands, check=True, shell=shell, stdout=sp.PIPE,
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/subprocess.py", line 524, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '['adb', '-s', '0cd7d2df9906', 'shell', 'settings', 'put', 'global', 'enable_gpu_debug_layers', '1']' returned non-zero exit status 255.
The application contains libLWI.so that is renamed to libMGD.so.
Streamline successfully connects to the application and gets the Timeline.
The system is macOS BigSur 11.6.
What is wrong?
Hi!
According to the Performance Advisor User Guide, developers do not need to package libLWI.so with the application starting from Android 10.
Have you tried removing it from the project?
Yes, I've removed the libLWI.so but it doesn't help. "enable_gpu_debug_layers" still fails.
If you run the command by hand in a terminal, do you get any useful error log? This is a standard Android property which should be writable if the device is in developer mode.
That said, the Redme 7A is a Snapdragon-based device, so Performance Advisor isn't going to give you anything useful. It's a tool for Mali GPUs, and won't work on Adreno.
