gatord refusing to copy to /data/data/%APP_NAME%/
Hi, everyone!
I'm trying to profile a Unity application using Streamline on a Samsung A20e. However I'm stuck in the process, because gatord is refusing to copy to the target app directory.
Steps I have done:
-Build a development build of the app (Also tried to set it explicitly to debuggable  in the manifest)
-Deploy the app on the phone
-Run the app
-Close the app
-execute gatorme.bat (this is the default gatorme.bat from github)
I'm calling gatorme.bat like this:
gatorme.bat com.replaced.replaced G71 ./bin/gatord
gatorme.bat fails on the following line:
adb shell run-as com.replaced.replaced cp /data/local/tmp/gatord /data/data/com.replaced.replaced/
With this error message:
cp: Skipped dir '/data/data/com.replaced.replaced//gatord': No such file or directory
Stuff I tried that didn't fix the problem:
-Fix the double slashes in the path.
-Make the app explicitly debuggable in AndroidManifest.xml
-Copy gatord by hand to Android/data/com.replaced.replaced (but I'm guessing this isn't the same path)
Any help would be welcome!
Thx!
