I was trying to install the Simple Triangle Application from Graphics and Mobile Gaming Course on Android Virtual Device Simulator as well as on hardware(Adreno GPU because I don't own a Mali GPU based ARM Device).
while building and cleaning the solution on android studio , there isn't any syntactical or compiler error.
But after installing, the application fails to run/stops working and every time I get an crashing message as shown in the above screenshots at the exact same line highlighted in the screenshot.
Any Help will be highly appreciated.
Thanks in advance.
Hi! Have you tried using different options for OpenGL ES renderer and OpenGL ES API level in the emulator settings?
yeah mate, I tried different options of API level ranging from 14 to 30 and also used OpenGL renderer 1.0 , 2.0 , 3.0 , 3.1 in the android emulator settings.
also I tried to change the architecture from normal x86/x64 to armeabi-v7a and armeabi-v8 in android emulator settings.
Still the same crashing message appears in the screenshot posted above at the exact same line highlighted as red.
Thanks for the report, we've raised with this with team who own this course.
Kind regards, Pete
Hi there,
We will look into this and see if we are able to reproduce the error.
Will get back to you when we hopefully have a more informed answer or can ask you some questions.
After testing the lab I have also been reproducing the same error. We will revise the material and modify it to prevent users running into this in the future.
thanks a lot peter.
let me know if the issue gets resolved after raising this with the team who owns this course.
highly appreciated , helpful and grateful.
thanks.
i am still unable to get past errors shown in above screenshots in red highlighted colors.
i tried various different permutations and combinations , still stuck at the exact same error highlighted in red color.
thanks , highly appreciated , helpful and grateful.
thanks a lot.
cheers.
that's the most basic simple triangle application from graphics and mobile gaming course.
i am ready to zip the entire folder and attach it via google drive or something and send it to specific technical team via email who can resolve it sooner or later.
highly appreciated , grateful and helpful.
